- Thank you received: 83
650 engine mods, advice needed
- Powerstroke_fan
13 Sep 2012 19:07 #548511
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic 650 engine mods, advice needed
I dont know how much you can go with valve/piston clearance issues. IF your going thru all that work why dont you just put some bigger pistons in?
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Tomolu5
- Thank you received: 45
13 Sep 2012 19:24 #548514
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic 650 engine mods, advice needed
Larry C. Talked me out of taking any extra meat off of the head, and after listening to him, I agree. Most attempts to save cash result in spending even more!
Mine:
- Mellvis
- Thank you received: 3
13 Sep 2012 21:56 #548540
by Mellvis
Replied by Mellvis on topic 650 engine mods, advice needed
Mark, now I understand about the rolling when the cam chain is tightened. Powerstrokefan, These mods cost no money as I have the parts (other than intakes which I have to replace anyway) and I have a buddy who will machine for free for me. Tomolu5, I haven't started the mill yet, just trying to get opinion from those of you who have been here before (such as yourself) and thanks for the advice. What was it that made you decide not to shave the head?
Thanks guys, I'm glad to be learning.
- Mark Wing
- Thank you received: 22
13 Sep 2012 22:22 #548544
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic 650 engine mods, advice needed
The reason I said and the Yoshimura pistons make plenty of compression.
Mark
Mark
Yorba Linda Cal.
- zukdave
- Thank you received: 229
15 Sep 2012 13:11 #548850
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic 650 engine mods, advice needed
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- wireman
- Thank you received: 299
15 Sep 2012 13:31 #548853
by wireman
Replied by wireman on topic 650 engine mods, advice needed
Thats a serious size differance!
- OnkelB
- Thank you received: 80
15 Sep 2012 15:56 #548879
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic 650 engine mods, advice needed
Mellvis, if I remember correctly your 650 is a D (SR) model, right?
If so it has a single roller cam chain which raises some issues:
- If you want to run a 750 cylinder block you need to make sure the block has the provisions for the cam chain idler sprocket shafts (marked red in the pic below), if it doesn't it won't work with a single roller cam chain setup.
- You also need to make sure that the cylinder head you decide to use has the 4 mount holes for the top cam chain idler sprocket (GPz 750 heads haven't got the mounts, so they won't work with a single roller cam chain setup).
Lastly, to fit a 750 cylinder block to an early (pre-81) 650 bottom end you will need to machine the upper case at the cylinder base (750 sleeves are too large to fit an early 650 case) = splitting the cases.
- steell
16 Sep 2012 17:21 #549097
by steell
Replied by steell on topic 650 engine mods, advice needed
You can drill the four mounting holes for the idler sprocket in the GPz750 head, all the other 750s seem to have them pre-drilled.
- Mellvis
17 Sep 2012 00:14 #549172
by Mellvis
Zukedave, thanks for the visual! I think you talked me into it.
So it's either use a 750 engine or bore the top case AND use the 750 cylinders and head? Yes, my bike is the d model but it has the 1978 B model engine, so it has the old style cam chain. I was going to use the old cam sprockets on the gpz cams, or so I think I can do that. If I remember right there was a discussion about the 750 using a larger wrist pin than the 650. If so, can the 650 rod be reamed to fit the 750 wrist pin, or will the 750 rod match the 650 crank journal? Also, is there enough material to just bore the cylinders to a 750 piston? Thanks again guys.
- steell
17 Sep 2012 13:00 #549235
by steell
I think 650 and 750 rods are the same, and there is no room to bore a 650 liner to 750 size. You can however bore the 650 jug to accept the 750 liner.
750 Turbo uses a larger wrist pin, not the regular 750.
650 didn't get the HyVo style chain till 81 model.
