- Thank you received: 3
650 engine mods, advice needed
- Mellvis
- wireman
- Thank you received: 299
Its more important to get efficient flow from one end to the other than to make huge cuts.
Im not sure about the exhuast ports on a 650 head but ill put up an old picture of exhuast ports on an early 81-82 gpz1100 head I did years ago since Im having trouble loading pictures of new work on computer. :sick:
As far as milling head Id just make sure its flat,if you want to bump compression up I prefer to have bottem of cylinder milled to zero out the deck on highest piston.
Attachment 005_05_0001.JPG not found
- JR
- Thank you received: 448
- zukdave
- Thank you received: 229
a 750 motor to start with.
My stock 83 gpz750 motor with VM29's go's low 12's
spinin the tire.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Mellvis
- baldy110
- Thank you received: 512
No they will not, the bolt patterns are different. However you can get the GPZ750 manifolds onto the KZ650 intakes by elongating the holes. The KZ650 manifolds will not fit the GPZ750, to small. The earlier KZ1000 manifolds will fit the GPZ750 intakes which will allow you to put on the VM28 or VM29 carbs onto the GPZ head.Mellvis wrote: Does a 750GPZ head take the same intake rubbers as the earlier 650/750? I was thinking it required a much larger manifold.
- zukdave
sloted the bolt hole's on my 650 boot's to fit.
When did the 29's I called Robert at Z1 ent.
told him VM29's and he sent me some boot's I filed hole's
and their a deadnut match to the port.
I'll go get a pic.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- OldSchoolZ
- Thank you received: 33
Remember, "Nothing Replaces Displacement"
Remember, don't work on your bike so much you never ride it.
- Mark Wing
Mark
Yorba Linda Cal.
- Mellvis
Thanks to everyone so far, these are the questions I didn't know to ask.
- Mark Wing
Mark
Yorba Linda Cal.
- baldy110
