Fuse box question
- BRABBIT04161991
- Thank you received: 2098
- DiamondSkyBlue1000
- Thank you received: 40
What year/model are we talking about? What are you trying to do? Any modifications we need to know about?
- BRABBIT04161991
DiamondSkyBlue1000 wrote: Really not enough info. Don't ground the RED/WHITE wire, it's coming directly off a fuse. That means it's connected to the 12V source.
Sorry its an 2001 kz1000p. The only thing I'm trying to accomplish is get rid of the old bulb fuses for the ones you'd find in your car or truck. There are not any modifications done to the bike other than the new fuse box. What do you mean the 12v source?? like another positive wire to the ignition??
- MFolks
- Thank you received: 540
www.cyclepsycho.com/kz1000p/kz1000p.html
- BRABBIT04161991
MFolks wrote: Here, look this over to find your wires:
I've been basing my entire rewiring off of this diagram and its not showing where the wires connect to it says just the connector and that's it. I'm so lost when it comes to wiring, but I'm so close I don't wanna take it to the shop now because I know it'll be something very simple, I'm just too blonde to figure it out
- MFolks
Does your bikes battery charge OK? Do the brake lights and turn signals work? Headlight good?
- BRABBIT04161991
Honestly I don't know if any of that stuff works I don't have the turn signals or head light mounted up yet so I'm not too sure.
Now here's something odd I did notice yesterday. When I turn the key on I get the oil and neutral light to come on but when I turn it all the way over the lights turn off as if I have no power.
- MFolks
BRABBIT04161991 wrote: ...When I turn the key on I get the oil and neutral light to come on but when I turn it all the way over the lights turn off as if I have no power.
when I turn it all the way over the lights turn off as if I have no power -- does the tail light stay lit in this switch position?
- BRABBIT04161991
- BRABBIT04161991
