Overheated engine = engine problems?
- XL777
Attachment incam2inner.JPG not found
ex cam 2 inner
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
- XL777
Attachment incam4inner.JPG not found
in cam4 inner
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- XL777
Attachment incam4outer.JPG not found
in cam4 outer
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- XL777
Did find some cracking in the rubber spacers under the cam chain sprocket.
As well the rubber cam plugs were melted inside ha
I'm going to check the torque on the main bolts that bolt the cyclinders to the bottom end in the hope that fixes my bottom gasket leak ha
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- Old Man Rock
- Thank you received: 225
Unless you sucked the oil out (turkey baster) or your oil is extremely clean and I'm not seeing it correctly, there should be some oil puddles in the bottom of each journal (over the shim area) especially in the exhaust journals due to engine tilt angles.
Your lobes seem wet but all else seem done dry...
Since your post is in regards to engine over heating, have you measured your oil pressure...?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- Motor Head
- Thank you received: 391
Old Man Rock wrote: Maybe it's me eyes but.... The cam journals seem dry of oil!
this Picture should have a big wet puddle of nice clean oil.
- kawasaki mike
- kawasaki mike
- Thank you received: 4
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
- bountyhunter
- Thank you received: 337
- XL777
Any opinions on those lobes? They measure in tolerance.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- 4TheKZ1000
- Visitor
I think those cams are toast...those are the worst cams I have seen....I really dont see the oil sitting in the top end as others have said....I think im the 2nd or 3rd person to say this....I guess we are all wrong and your right with a burnt up top end ????? I would check the oiling system.
Good Luck
- baldy110
- Thank you received: 512
XL777 wrote: No there is lots of oil. It's just been changed so it's clean.
By "lots" what exactly is the oil pressure and how did you measure it? Just because there is oil in the crankcase does not mean you have oil pressure.
