- Thank you received: 45
is this a no go?
- Tomolu5
Attachment uploadfromtaptalk1346028881593.jpg not found
This stuff will grab it
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- OldSchoolZ
- Thank you received: 33
Not as easy as simply sliding in a new bearing on a tranny shaft.
Any bearing thats spun has to be replaced.
Remember, don't work on your bike so much you never ride it.
- Bozo
- Ride it like u stole it
- Thank you received: 105
- turboguzzi
- Thank you received: 72
maybe show us pics of the shells?
a spun shell will have the anti spin tab flattend, so that would tell you.
if the tabs are fine, then there nothing to worry about
- Motor Head
- Thank you received: 391
The cases should be Torqued together and the bearing bore measured for both size/ diameter/ roundness etc. There is where you will find if it is usable as is. Don't Punch the surface, as this will distort the new bearing shell, causing strange wear patterns, and possible seizure. Many engine parts can be re-machined for the bearings to fit it, it is called Align- Boring. On your Kawasaki it would mean an oversize bearing for the outside dia, to fit the oversize hole. I doubt there is a bearing listed for it by application. It would have to be something found to fit by size, and might prove hard to locate. I'm sure Kawasaki would replace the cases for a bad bearing bore.
- les holt
- Thank you received: 288
Just my 2 cents. :whistle:
Better yet, look at the bearings that came out of it for a slipped tang and post a pic of the bearings that came out of it
Les
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
I believe this whole thread has confused the majority that has read it. It appears to me most on here are thinking he's referring to a crankshaft bearing, which his first sentence directed you to. The pic of the questionable bearing bore is referring to the tranny output shaft bearing bore in his upper case halve.Pop147 wrote: There is a chip on out put shaft upper case half. It feels smooth to the touch but, its fairly deep. Also there is some wear on the side of the crank case upper half. Is this case half reusable?
That doesn't look like wear on your case in the first pic. Unless I'm not seeing what you are referring to.
The bearing bore looks like it should hold a new bearing. Most output shaft bearing failures are caused by chain being too tight.
The suggestions to use the bearing retaining compound will work on the output shaft bearing if used sparingly. No way it will work on a split crank bearing shell. :S
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- wireman
- Thank you received: 299
- BlackZ1R
That pattern looked like where the thrust bearing was installed. New bearings should do the trick if the thrust surface on the crank halves aren't worn.
Kawasaki
- wireman
- Motor Head
- BlackZ1R
Kawasaki
