is this a no go?
26 Aug 2012 13:42 #544854 by Pop147
is this a no go? was created by Pop147
There is a chip on out put shaft upper case half. It feels smooth to the touch but, its fairly deep. Also there is some wear on the side of the crank case upper half. Is this case half reusable?
  • wireman
26 Aug 2012 14:11 #544857 by wireman
Replied by wireman on topic is this a no go?
What kind of bike? Id have the crankshaft checked B)
26 Aug 2012 14:24 #544858 by Pop147
Replied by Pop147 on topic is this a no go?
kz750 b4
  • wireman
26 Aug 2012 14:40 #544863 by wireman
Is there a hole in the case for a pin to keep that bearing from spinning? B)
26 Aug 2012 15:21 #544867 by OldSchoolZ
Replied by OldSchoolZ on topic is this a no go?
It appears the bearing had seized at least slightly and spun. When you install your new bearing tighten everything and make sure you cant move the bearing by lightly tapping the outter casing.
It should remain tight. With a new free spinning bearing, it shouldnt stress the case anymore.
Bottom line is, that bearing needs to be tight when cases are tightened.
Remember, don't work on your bike so much you never ride it.
26 Aug 2012 16:12 #544881 by bountyhunter
Replied by bountyhunter on topic is this a no go?
OldSchoolZ wrote: It appears the bearing had seized at least slightly and spun. When you install your new bearing tighten everything and make sure you cant move the bearing by lightly tapping the outter casing.
dumb question: could you use some kind of adhesive "dots" when you install the insert so it can't spin while it breaks in?
  • wireman
26 Aug 2012 16:34 #544883 by wireman
Ive seen them loc tited before to hold the,not sure if I agree with it though B)
26 Aug 2012 17:35 #544889 by Pop147
well while im here im going to take the transmission apart and the manual says to get new circlips can i use any circlips or just oem from Kawasaki?
  • wireman
26 Aug 2012 17:51 #544892 by wireman
Id go oem B)
26 Aug 2012 19:14 #544903 by Pop147
oldschool are you talking about the waer in picture 5043?
26 Aug 2012 19:53 - 26 Aug 2012 19:54 #544912 by OldSchoolZ
yea, I was looking at the aluminum that has been scored by the outer bearing spinning.
I was pretty sure you were referring to an input or output shaft for the tranny.
Another thing I've seen done to take up space on a spun bearing was to take a center punch(pointed) and centerpunch a small mark where the bearing makes contact with the case. I'de make about 10 punch marks evenly spaced in a circle. This will push a little bit of the aluminum upwards and take up the gap made by the spun bearing. I've done it before and worked fine, some use a small bit of locktite in conjunction with the punch marks, its actually a decent fix for no money. I suspect it would be a very long time before you have to worry about a new bearing trying to spin.
Last edit: 26 Aug 2012 19:54 by OldSchoolZ.
26 Aug 2012 21:41 #544929 by Pop147
No that picture is of the crank shaft. Number 1 is where the chunk of metal is missing and number 2 is where the wear is. Sorry that was my fault.
