- Thank you received: 2098
Rough riding after valve clearance adjustment
24 Nov 2012 23:03 #559921
by Patton
This error is what may cause the problem described as, the throttle lever never comes into contact with the throttle stop screw. Is that right? The screw seems effectively useless....
Replied by Patton on topic Rough riding after valve clearance adjustment
A mistake is sometimes made during the bench sync by failing to leave sufficient thread remaining on the idle adjustment screw to permit further lowering the throttle slides as is often required during the later running sync.daless wrote:
donthaveakawman wrote: I'm almost willing to be that sounds like the wheel bearing is bad. you want to get that checked asap.
What's that in reference to?
Patton wrote: Carbs need a proper bench sync.
Yeah... Thought I followed that procedure pretty well. Guess not. Any clues as to what went wrong?
- donthaveakawman
- Visitor
25 Nov 2012 06:32 #559967
by donthaveakawman
Replied by donthaveakawman on topic Rough riding after valve clearance adjustment
I don't think this thread is doing me any good, I developed a wheel clicking noise saturday as I was Passing a car that was doing the speed limit. that is no good excuse to go faster than the speed limit, I know. It just seems whenever I do anything more than crack the throttle I am breaking the speed limit anyways.(by crack the throttle I mean have slight pressure on the play in the throttle) :ohmy:
