blue job or blue away
13 Aug 2012 15:04 #542292 by pete greek1
blue job or blue away was created by pete greek1
has anyone used these products to remove slight gold & bluing on there pipes ? and what kind of results came about ?
13 Aug 2012 15:51 #542299 by bountyhunter
Replied by bountyhunter on topic blue job or blue away
I didn't think anything would make single wall pipes stop turning blue.
13 Aug 2012 16:27 #542314 by pete greek1
Replied by pete greek1 on topic blue job or blue away
I"m trying what Patton does since I have the pipe off the bike, which is to paint the inside of the tubes with several thick coats of 1200 degree engine enamel, he says it works for him, so since I had the pipes off anyway, all I"ve got to loose is about $8.00, I saw a video on you tube about Blue job chrome polish & it removed all the blue & gold
  • 4TheKZ1000
  • Visitor
13 Aug 2012 17:17 #542326 by 4TheKZ1000
Replied by 4TheKZ1000 on topic blue job or blue away
bountyhunter wrote: I didn't think anything would make single wall pipes stop turning blue.
+1 on that....its just the thin metal of the pipe...going to blue no matter what. I really dont see these products doing that great of a job.
13 Aug 2012 17:41 - 13 Aug 2012 17:50 #542331 by martin_csr
Replied by martin_csr on topic blue job or blue away
I used blue job on a stock exhaust system. The stuff removed the brown stains from the mufflers, but it didn't do anything to the blueing on the headers, which was real bad. I think someone posted a blue job topic a few months back in which he had good results, so I guess it depends on how bad the staining is.
Last edit: 13 Aug 2012 17:50 by martin_csr.
13 Aug 2012 18:02 - 13 Aug 2012 18:10 #542339 by pete greek1
Martin, I have very light bluing, so if I can nip it in the butt,& remove what little bluing I have & the high temp paint trick works, its a cheap fix, if it does"nt...OH well... I"M sure you know that stock pipes are double walled, so if they were blued that bad, the the metal had to be blue all the way thru, ...you"ld never get the blue off....Pete
Last edit: 13 Aug 2012 18:10 by pete greek1. Reason: add more
13 Aug 2012 18:59 #542360 by Je77ekz1000a
Replied by Je77ekz1000a on topic blue job or blue away
Is the blue on the headers bad, or everyone just wants it off their chrome? I think it actually looks good on my bike, matches my paint scheme. :laugh:
Jesse Shasteen
77 KZ1000 A
Huntsville AL
13 Aug 2012 19:52 #542370 by RonKZ650
Replied by RonKZ650 on topic blue job or blue away
I've used Blue Away. It works, but don't expect to wipe it on and off and have the blue gone. It will take an hour or more per header of hard rubbing, then since it's a form of light abrasive your chrome will never be as shiney as it once was. I'm still very happy I used it.
13 Aug 2012 20:11 #542378 by peavylotus
Replied by peavylotus on topic blue job or blue away
I really like pipes turned blue and gold, the fade is beautiful and so vibrant. Haha I wish my pipes were chromed just so they could turn blue at head.
1980 KZ 1045 LTD Currently Workin' It Out
  • Killman
  • Now with 99% more ducks
13 Aug 2012 20:47 #542395 by Killman
Replied by Killman on topic blue job or blue away
Hey Je77ekz1000a that's a really nice job on your tank. I dig how bright clean and retro it looks.
1983 kz440 ltd
Quack
14 Aug 2012 01:17 #542459 by pete greek1
hey...Je77ekz1000a, is lying, ....his pipes did"nt turn blue,....he painted them blue...to match his paint job :laugh: :laugh: :laugh:
14 Aug 2012 02:00 #542467 by damarble
Replied by damarble on topic blue job or blue away
martin_csr wrote: I used blue job on a stock exhaust system. The stuff removed the brown stains from the mufflers, but it didn't do anything to the blueing on the headers, which was real bad. I think someone posted a blue job topic a few months back in which he had good results, so I guess it depends on how bad the staining is.
I may have to try it, all I want to get rid of is the brown stains, I like the blue.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
