blue job or blue away
- pete greek1
13 Aug 2012 15:04
has anyone used these products to remove slight gold & bluing on there pipes ? and what kind of results came about ?
- bountyhunter
Re: blue job or blue away
13 Aug 2012 15:51
I didn't think anything would make single wall pipes stop turning blue.
- pete greek1
13 Aug 2012 16:27
I"m trying what Patton does since I have the pipe off the bike, which is to paint the inside of the tubes with several thick coats of 1200 degree engine enamel, he says it works for him, so since I had the pipes off anyway, all I"ve got to loose is about $8.00, I saw a video on you tube about Blue job chrome polish & it removed all the blue & gold
- 4TheKZ1000
13 Aug 2012 17:17bountyhunter wrote: I didn't think anything would make single wall pipes stop turning blue.
+1 on that....its just the thin metal of the pipe...going to blue no matter what. I really dont see these products doing that great of a job.
13 Aug 2012 17:41 - 13 Aug 2012 17:50
I used blue job on a stock exhaust system. The stuff removed the brown stains from the mufflers, but it didn't do anything to the blueing on the headers, which was real bad. I think someone posted a blue job topic a few months back in which he had good results, so I guess it depends on how bad the staining is.
Last edit: 13 Aug 2012 17:50 by martin_csr.
- pete greek1
13 Aug 2012 18:02 - 13 Aug 2012 18:10
Martin, I have very light bluing, so if I can nip it in the butt,& remove what little bluing I have & the high temp paint trick works, its a cheap fix, if it does"nt...OH well... I"M sure you know that stock pipes are double walled, so if they were blued that bad, the the metal had to be blue all the way thru, ...you"ld never get the blue off....Pete
Last edit: 13 Aug 2012 18:10 by pete greek1. Reason: add more
- Je77ekz1000a
13 Aug 2012 18:59
Is the blue on the headers bad, or everyone just wants it off their chrome? I think it actually looks good on my bike, matches my paint scheme. :laugh:
Jesse Shasteen
77 KZ1000 A
Huntsville AL
77 KZ1000 A
Huntsville AL
- RonKZ650
13 Aug 2012 19:52
I've used Blue Away. It works, but don't expect to wipe it on and off and have the blue gone. It will take an hour or more per header of hard rubbing, then since it's a form of light abrasive your chrome will never be as shiney as it once was. I'm still very happy I used it.
- peavylotus
- Movin on up
13 Aug 2012 20:11
I really like pipes turned blue and gold, the fade is beautiful and so vibrant. Haha I wish my pipes were chromed just so they could turn blue at head.
1980 KZ 1045 LTD Currently Workin' It Out
- Killman
- Now with 99% more ducks
13 Aug 2012 20:47
Hey Je77ekz1000a that's a really nice job on your tank. I dig how bright clean and retro it looks.
1983 kz440 ltd
Quack
Quack
- pete greek1
14 Aug 2012 01:17
hey...Je77ekz1000a, is lying, ....his pipes did"nt turn blue,....he painted them blue...to match his paint job :laugh: :laugh: :laugh:
- damarble
14 Aug 2012 02:00martin_csr wrote: I used blue job on a stock exhaust system. The stuff removed the brown stains from the mufflers, but it didn't do anything to the blueing on the headers, which was real bad. I think someone posted a blue job topic a few months back in which he had good results, so I guess it depends on how bad the staining is.
I may have to try it, all I want to get rid of is the brown stains, I like the blue.
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
