- Thank you received: 52
Tacho cable still freaking leaking
- Kawboy74
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- Motor Head
- Thank you received: 391
- bluej58
- Thank you received: 511
I didn't want to pry it out because I trying to keep the engine closed for cleaning , but it's defiantly rubber and deep too.
Can you fish around underneath the metal face or is it a straight drilled hole ?
JD
78 KZ1000 A2A
- KZ1000inaus
- Luminous Red KZ1000 A2
- Thank you received: 4
Motor Head wrote: Difficult to tell from the picture you posted, but it looks like a gap around the edge of the circumference on the end of where the seal should fit. Are you sure that is Solid Metal? And not some washer put there by a PO? (PO= Previous Owner). Put a small punch in from the engine end of the assy, and drive the seal and what looks like a washer out. Thats what it looks like anyway. If not consider getting another housing assy.
yea sorry about quality but my missus and cameras.. well lets not go there..
I said the same to her so to prove the point she sent a video of her tapping it with a screwdriver and it's definitely metal,
when i get home i'll try prising it out as it could be a PO fitted washer !!
but you can see why i was getting confused!
- KZ1000inaus
the seal underneath is completely knackered and rock hard, now comes the fun bit of getting that out!
I notice you can buy new kits on ebay for around 30-40 bucks i might have to order one of those as mine's a little bit chewed up.
- bluej58
Your housing doesn't look that bad from here
If you get a proper O ring for the shaft and are able to pull that seal out safely I think you'll be alright.
You might try smearing a little Permatex black where the seal meets the wall of the housing and press it in.
Then again it would be a drag to have to mess with it any more so it's your call.
Good luck
JD
78 KZ1000 A2A
- pete greek1
- Thank you received: 185
- Old Man Rock
- Thank you received: 225
Use Dupli-Color wheel base paint on them nails, won't chip while wrenching on your kawi... :whistle:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- KZ1000inaus
haha :laugh:Old Man Rock wrote: "i'm not wearing nail varnish.. honestly." .... :blush: Yeah sure it is wifey poo...
Ok you got me.. i'll try the duplicolor if that's what you recommend.. :lol:
old seal came out easily when i heated up the housing
fitted new and went for a test ride and not leaking yet
buy the way the old girl (the bike not wife) won the peoples choice at a local classic bike show last week !!
Off to another show tomo but it's much larger and i feel there will be a fair amount of competition so just viewing not entering.
Thanks for all the advice guys (especially the nail polish!!)
Attachment IMG_4290.jpg not found
