- Thank you received: 4
Tacho cable still freaking leaking
- KZ1000inaus
- Luminous Red KZ1000 A2
I have made sure the cable screws on square as i understand that can be a problem
I'm assuming the seals aren't good enough quality.
any ideas?
- Thank you received: 2098
Perhaps all remnants of the old inner seal weren't completely removed before installing the new seal.
Or maybe the new seal was damaged during installation. Or was improperly installed.
A dental pic is useful when dislodging and picking out all the remnants of an old encrusted, carbonized inner seal. Together with a bright light and magnification to look inside and inspect the interior of the tach housing to assure it's clean and clear before installing the new seal.
Or maybe the new o'ring was damaged during installation of the tach drive housing.
Tach drive should remain completely oil tight even without the cable attached.
- ramtough_63
Patton wrote: Would guess their being an issue involving removal and/or installation of the inner seal that's supposed to prevent oil from escaping around the tach drive shaft.
AMEN on getting the old seal out my first attempt was a disaster! I even bought a different tach drive
not realizing I just didnt do a good enough job removing the old inner seal (thought I tore something up)
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- bluej58
- Thank you received: 511
The drag is that you have to take the valve cover off again :pinch:
Wipe and clean all the surfaces real good too, and apply a little Yammabond over the end plugs if you've got some handy.
If you use a sealant give it a day to cure before firing her up.
Good luck,JD
78 KZ1000 A2A
- KZ1000inaus
I'll get another seal and make sure all the old one is out.
- dfinnegan71
1981 GPZ 550 mild custom
- Thank you received: 2829
Attachment 0000_2012-08-07.jpg not found
- dfinnegan71
Thanks 650ed!
- KZ1000inaus
Oh it looks like I might be missing the 92065-103 as i don't recall ever seeing that one.650ed wrote: It should not be leaking that quickly. Did you replace all 3 pieces that seal the tach drive? If not, I would suggest you do, as that is the best way to stop the leak. All 3 parts are still available from Kawasaki, so any dealer can get them for you. See highlighted parts below:
[/attachment]
Does it sit in the end of the tacho cable?
- KZ1000inaus
dfinnegan71 wrote: Oh boy, I seem to be missing out on the gasket # 11009. I changed the other two items but didn't even know I need that there gasket. That explains alot!
Thanks 650ed!
haha me too!!
it must have been missing since the last owner..
Attachment 0000b.JPG not found
- KZ1000inaus
but he did ask me which way i'd put the other seal in and i said pointy end into engine (the way it looks like it should) which i'm told is the wrong way !
He said I've probably damaged it so i'm gonna get another today and fit it around the right way!!
