- Thank you received: 2829
Shim Sizes - Valve Clearances
- thejij
- KZ 750 Spectre N1
1982 KZ750 Spectre N1 - Shaft Drive
Four-stroke, 4 Cylinder, Dual Over Head Camshaft
Engine No: KZ750NE000001 -
Frame No: JKAKZDN1()CA000001 -
Service Manual No: Same as Z(KZ)750-F1
Owner's Manual No: 99920-1146-07
thejij wrote: At this point I might just loosen it ...move it in correct place ...bolt down again ha aha over and over
Keep in mind - the more times you loosen and tighten those cam caps the more likely you are to strip the threads in that 30 year old aluminum head. You really are playing with fire. Ed
- peter1958
- Banned
- Thank you received: 198
- thejij
- KZ 750 Spectre N1
- thejij
- KZ 750 Spectre N1
- kzz1king
- Thank you received: 52
Wayne
Home built KZ1000 turbo setup
- thejij
- KZ 750 Spectre N1
I have now figured out that 1 and 2 exhaust and 2 intake are okay with the 2.40 shims .. and I need the following shims in the rest.
3 x 2.35
1 x 2.30
1 x 2.25
What a fun job (not) but at least im learning alot !!! hahahaah
- thejij
- KZ 750 Spectre N1
Cam timing is correct... timing advancer is correct , been tested according to manual.
Something is awful in the lower end tho... dont know what it is... I took a video.. wonder if you can hear it well, but its in the left side it seems... its LOUD.
.. could it be crank? Primary chain? I know these bikes are known for their solid bottom ends.. but something aint right.
- bountyhunter
- Thank you received: 337
- thejij
- KZ 750 Spectre N1
Hell, finding a throttle cable was a pain in the arse... dont want to go looking for a new bottom end.
