has compression, has spark, not running one cylind
- joshjones84
82 KZ550 LTD
- Thank you received: 1656
- Thank you received: 2098
joshjones84 wrote: got my bike up and running today! but.... the #4 cylinder is not running. the exhaust is cold. i took out the spark plug and laid it on the engine and i have spark. did a compression test and it was over 100. i cleaned the carbs before starting it up. does anyone know whats going on? what i should look for?
Does the spark plug tip appear damp with a gasoline odor? Perhaps dripping wet with gasoline? Or dry?
Could spray starting fluid into #4 air intake to see whether #4 begins combusting, which would indicate fuel starvation (for whatever reason) in #4 cylinder.
- faffi
- Thank you received: 36
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- 74ullc
- Thank you received: 23
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
- joshjones84
82 KZ550 LTD
- faffi
That said, a strobe light will immediately tell you if it's sparking inside or not.
If you have a reliable spark and you have compression, only fuel is left. Try starter fluid and see of it fires.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Here's one way to clean the pilot circuit.
- joshjones84
82 KZ550 LTD
- kcornell6
I have literally the exact same problem as you. Where was the leak that you plugged with your finger?
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
