has compression, has spark, not running one cylind
29 Jul 2012 10:11 #539355 by joshjones84
got my bike up and running today! but.... the #4 cylinder is not running. the exhaust is cold. i took out the spark plug and laid it on the engine and i have spark. did a compression test and it was over 100. i cleaned the carbs before starting it up. does anyone know whats going on? what i should look for?
82 KZ550 LTD
29 Jul 2012 10:25 #539359 by martin_csr
I had the exact same problem: spark but a cold pipe. Redoing the spark plug wire connections solved the problem.
29 Jul 2012 11:14 #539366 by Patton
joshjones84 wrote: got my bike up and running today! but.... the #4 cylinder is not running. the exhaust is cold. i took out the spark plug and laid it on the engine and i have spark. did a compression test and it was over 100. i cleaned the carbs before starting it up. does anyone know whats going on? what i should look for?
Does the spark plug tip appear damp with a gasoline odor? Perhaps dripping wet with gasoline? Or dry?
Could spray starting fluid into #4 air intake to see whether #4 begins combusting, which would indicate fuel starvation (for whatever reason) in #4 cylinder.
Good Fortune! :)
29 Jul 2012 11:43 #539369 by faffi
The only way to tell if you have a spark under compression is to hook up a strobe light when it's running. If the lamp doesn't flicker, you do not have a spark. If it shows a reliable spark, this particular cylinder doesn't get a mixtur that will burn.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
29 Jul 2012 15:13 #539399 by 74ullc
Vacuum cap on carb holder/boot missing? I'm not sure if your bike has vacuum ports in the holders but if it does and the cap is missing it can cause it to not fire at idle.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
04 Aug 2012 15:24 #540706 by joshjones84
Replied by joshjones84 on topic has compression, has spark, not running one cylind
UPDATE! i switched the spark plug wires off from the running cylinder to #4 and..... no luck. i unscrewed the drain on the float bowl and.... im getting fuel into the float bowl. i took out my spartk plug and.... i dont smell any gas. what the sh_t. what should i look for next?could something be sticking in the float bowl? i have a new valve in there. does the float need adjusted or is it a bigger problem? im running out of time for this summer! i want to ride it at least once!
82 KZ550 LTD
04 Aug 2012 16:17 #540716 by faffi
If you haven't tried it, try swapping spark plugs as well - even brand new ones can be bad.
That said, a strobe light will immediately tell you if it's sparking inside or not.
If you have a reliable spark and you have compression, only fuel is left. Try starter fluid and see of it fires.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
05 Aug 2012 17:24 #540869 by Powerstroke_fan
Replied by Powerstroke_fan on topic has compression, has spark, not running one cylind
I would say if theres not any gas on the plug, and its completely dry, Id start with the carbs.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
05 Aug 2012 18:58 #540882 by Patton
Blocked carb pilot circuit could be why fuel mixture isn't entering the combustion chamber.
Here's one way to clean the pilot circuit.
Good Fortune! :)
09 Aug 2012 13:45 #541554 by joshjones84
UP DATE!!!! i took off the float bowl, took out the jets, cleaned everything, put it back together and...... NOTHING!!!!!! so i left the bike running and decided to pack it up. went down to pick up my tools and i heard a faint pff pff pff pff pff pff pff... i reached around the carb area and i found an air leak. i put my finger over it and it started to idle real smooth! i left my finger on for a few and reached around to the #4 exhaust and....ITS HOT!!!!!! no i just need to find a plug for it and i should be set.
82 KZ550 LTD
10 Aug 2012 21:54 #541847 by kcornell6
Hey Josh,
I have literally the exact same problem as you. Where was the leak that you plugged with your finger?
V/R
Kev
96' KZ1000P Bobbed
81 GS850L
10 Aug 2012 22:38 #541862 by Patton
Good Fortune! :)
