Cylinder compression test - failed ??? :(
- Bunty27
Re: Cylinder compression test - failed ??? :(
09 Aug 2012 23:23
So my compression tester from ebay arrived and I just did a test on my engine. And I'm happy to report that the compression on each of the cylinders is ~145 psi.
Please ignore all my complaints about all sorts of things because I didn't know anything about any of this then. Thanks to you all, I learnt a lot about how an engine works, compression etc etc etc.
Glad to know that I have an engine that may have some good life left in it.
1982 KZ550 LTD
- Paroxyst
- KZ550 -82 B3. KZ550 A1. ZX550A1. CBR600F2
10 Aug 2012 01:54
I have 179 - 184psi in a cold engine. Isn´t 120 - 145psi very low?
- Del_Herring
10 Aug 2012 02:44
The specs on these thigns are pretty wide. I know on my 750 Spectre, the spec was from like 130 to 190. It was really looking mroe for whether they were close to each other. Some of it will be influenced by stuff like your intake and your valve settings. The more air you get in when all the valves are clsoed, the higher the compression will be, so there's a fair amount of variability.
1983 KZ750-N2 Spectre
- Paroxyst
10 Aug 2012 02:55Hmm and I didn´t know about having throttle open so I guess my values are very good (refurbishing valves and seats helpsDel_Herring wrote: The more air you get in when all the valves are clsoed, the higher the compression will be, so there's a fair amount of variability.
- faffi
10 Aug 2012 04:19
I would say that anything above 120 PSI is fully acceptable, and even as low as 100 PSI engines can deliver close to full power, depending on what cause the low pressure.
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
1980 F1 engine
B1 Points ignition
- Bunty27
12 Aug 2012 11:13
I was going with the KZ550 manual which said the pressures should be anywhere between 120 to 150.
1982 KZ550 LTD
