- Thank you received: 185
head nuts ?
- pete greek1
20 Jul 2012 11:47 #537265
by pete greek1
the head nuts are rusty on the 76 900 I just bought, & want to replace just the 4 outside ones for now, & the copper gasckets, can this be done if I alternate front on one side, back on the other side, & visa versa, or will I have to worry about leaks, & have to replace them all & the head gascket...Pete
head nuts ? was created by pete greek1
The following user(s) said Thank You: Powerstroke_fan
- Powerstroke_fan
- Thank you received: 83
20 Jul 2012 11:51 - 20 Jul 2012 11:51 #537266
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic head nuts ?
I would think if you done one at a time i think you would be ok.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
Last edit: 20 Jul 2012 11:51 by Powerstroke_fan.
- Thank you received: 797
20 Jul 2012 11:56 - 20 Jul 2012 11:57 #537269
by 531blackbanshee
Replied by 531blackbanshee on topic head nuts ?
do em one at a time(like powerstroke said,)retroque and you won't have any problems.
Last edit: 20 Jul 2012 11:57 by 531blackbanshee.
- pete greek1
20 Jul 2012 14:28 #537291
by pete greek1
Replied by pete greek1 on topic head nuts ?
Thanks, Leon, & Powerstroke, thats what I thought, but with all the experts on this forom, I figured I better check first, as I am no expert & dont want to take any chances...Pete
- wireman
- Thank you received: 299
20 Jul 2012 14:39 #537294
by wireman
Replied by wireman on topic head nuts ?
Worst case scenario if it leaks Leon will come replace head gasket for ya! :woohoo:
- Tomolu5
- Thank you received: 45
20 Jul 2012 14:45 #537296
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic head nuts ?
First time I've ever seen blue carbs!, like the paint otherwise. Oh yeah, should be good one at a time, recheck them after a heat cycle(when cold). Add a dab of oil to bottom of nut for cleaner torque reading( I know, iknow OCD)
Mine:
- wireman
20 Jul 2012 15:00 #537301
by wireman
So did you buy that from Ronkz650? :woohoo:
- pete greek1
20 Jul 2012 17:11 #537332
by pete greek1
Wireman,...if it starts leaking, I"ll have Leon give me directions over the phone, it should take me about 10 minutes, my tools are a pipe wrench & a screwdriver, as far as the blue carbs, after I put the 29 smoothies on it, I"m going to sell them to RonKZ 650 !!!! :laugh: :woohoo: :woohoo:
- LarryC
21 Jul 2012 07:56 - 21 Jul 2012 07:58 #537426
by LarryC
Larry C.
Replied by LarryC on topic head nuts ?
Make CERTAIN you torque all the head nuts and check them again after you heat cycle the motor one time. That should be on on a stone cold motor.
It's the failure to retorque the head after that first heat cycle that causes leaks.
BTW...did you buy that bike of Old Kawman? :side:
Old Kawman
Old Kawman
Larry C.
Last edit: 21 Jul 2012 07:58 by LarryC.
- Sorf
21 Jul 2012 08:29 #537430
by Sorf
Replied by Sorf on topic head nuts ?
Nice paint, have you got a bigger pic of it?
- pete greek1
21 Jul 2012 12:21 #537457
by pete greek1
This is what it looked like after I got it out of the van, it is stock, excepy for the kerker, pain job, & cal fab swingarm...never did like flame jobs too much, but this one caught my eye,...I..like it,...& yes Larry it does look a lot like Old Man Kaws bike !
Attachment DSCF1472.JPG not found
- pete greek1
23 Jul 2012 01:20 #537798
by pete greek1
