- Thank you received: 1
had floats set and benched sinicized
- zig
- bountyhunter
- Thank you received: 337
Popping means too lean, fuel levels are probably low.
- zig
- Thank you received: 2829
- zig
zig wrote: i took it to a carb shop and he did it but when im on it runs smoth but it dies out when on fuel on on pprim it dont well it does but not as offen i should have left it alone grrr
If they did not use the clear tube method to check the fuel level and then synch the carbs properly with the engine running both the fuel level and the carb synch may be off. As Bountyhunter said, setting the floats dry is not accurate, neither is "bench synching" the carbs. BTW, what do you mean by a "carb shop"? Ed
- zig
- zig
- bountyhunter
sounds like petcock is not turning off wellzig wrote: ok took me a while but i got floats st8en out :woohoo: still got a drip on number 3 took needle to bike shop they said its fine so ill deal with the drip its a faint drip but still a drip
- zig
- bountyhunter
Petcocks get crappy with age and leak gas. Some have rebuild kits.zig wrote: its a vac petcock it drips i belive when im riding it too im lost on this deal lol
- peavylotus
- Movin on up
- Thank you received: 15
You should still adjust your floats with the clear tube, but your floats being adjusted incorrectly does not govern how much fuel goes into the chamber at any given moment. It will either overflow out the carb, or choke the engine of fuel on heavy throttle. It doesn't govern constant mixture.
I am totally open to discussion if anyone disagrees with my logic.
1980 KZ 1045 LTD Currently Workin' It Out
