- Thank you received: 185
2 questions
- pete greek1
15 Jul 2012 12:24 #536067
by pete greek1
Replied by pete greek1 on topic 2 questions
OK ...I"m confused, Babbits lists the part # as 92022-215 as plain 10 mm washer, for $4.68 a piece, KZ 900.com same part # .32 cents a piece, Bike Bandit same part # $5.93 a piece, ...& are the copper washers needed for all the head bolts, or just the four outer bolts ???
- 4TheKZ1000
- Visitor
15 Jul 2012 13:04 - 15 Jul 2012 13:13 #536070
by 4TheKZ1000
Replied by 4TheKZ1000 on topic 2 questions
the copper are needed for the two outboard studs on each side. oil travels up the 2 rear engine stud from the lower cases to oil the top end. the copper washers seals the top of cylnder head so you dont get leaks. just use stainless on the others/
Last edit: 15 Jul 2012 13:13 by 4TheKZ1000.
- pete greek1
15 Jul 2012 16:50 #536119
by pete greek1
O.K...was going thru my parts drawers, and I found a package of 12 new copper washers, now I think I"ll order 24 steel washers from KZ 900.com for .32 cents each & I"ll be good for 3 heads !!!!
