- Thank you received: 185
2 questions
- pete greek1
- 4TheKZ1000
- Visitor
- pig9r
- Thank you received: 10
- peter1958
- Banned
- Thank you received: 198
- Tomolu5
- Thank you received: 45
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- pete greek1
- wireman
- Thank you received: 299
- wireman
When you heat up a piece of copper thats been crushed then toss it in water it will stay expanded.
- pig9r
wireman wrote: When you heat something just like a pipe fitting to loosen it up it will expand,but as it cools it shrinks back down.
Problem is when you quench it, it doesn't stay soft and is more brittle. If it air cools it will stay soft. Either way they will likely seal just fine.
- wireman
Although people have been tempering steel in brine/salt water since long before either of us were around.
- pig9r
wireman wrote: Ive been sweating copper for a living on/off for last 30 years,copper is not steel cooling it off with water doesnt hurt it like it does steel.
You're right, i wasn't thinking, nonferrous, so same result either way.
- LarryC
You have two options. Toss them and get new ones or lightly sand them and spray them with copper coat. You could even use a dab of engine case sealer on them.
Larry C.
