2 questions
14 Jul 2012 14:06 #535860 by pete greek1
2 questions was created by pete greek1
can I reuse the copper washers for the head bolts ? and would 29 smoothbores work on a stock 76 LTD 900, with a kerker, stock airbox ?
  • 4TheKZ1000
  • Visitor
14 Jul 2012 14:13 - 14 Jul 2012 14:14 #535861 by 4TheKZ1000
Replied by 4TheKZ1000 on topic 2 questions
on the copper washers....if they are ok without major wear grooves should seal ok, put the best side down. on the 29's....I have seen them on close to stock 1000's but I really dont know about 900's....will need someone else to chime in on that one.
Last edit: 14 Jul 2012 14:14 by 4TheKZ1000.
14 Jul 2012 17:14 #535895 by pig9r
Replied by pig9r on topic 2 questions
I would anneal them by heating them up with a propane torch until they are glowing red hot. A propane torch is good because it won't get hot enough to melt them. Then let them air cool - don't quench them. Then lay some sand paper flat and clean them up and remove the old ridges from the nuts.
14 Jul 2012 17:20 #535897 by peter1958
14 Jul 2012 17:30 #535900 by Tomolu5
Replied by Tomolu5 on topic 2 questions
+ 1 on annealing them
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
14 Jul 2012 19:23 #535914 by pete greek1
Replied by pete greek1 on topic 2 questions
Thanks to every one for the answers to my questions....I just was"nt sure...Pete
  • wireman
14 Jul 2012 21:47 #535933 by wireman
Replied by wireman on topic 2 questions
Heat them up and toss them in a bucket of cold water B)
  • wireman
14 Jul 2012 21:57 #535936 by wireman
When you heat something just like a pipe fitting to loosen it up it will expand,but as it cools it shrinks back down.
When you heat up a piece of copper thats been crushed then toss it in water it will stay expanded. B)
14 Jul 2012 22:31 #535944 by pig9r
wireman wrote: When you heat something just like a pipe fitting to loosen it up it will expand,but as it cools it shrinks back down.
Problem is when you quench it, it doesn't stay soft and is more brittle. If it air cools it will stay soft. Either way they will likely seal just fine.
  • wireman
14 Jul 2012 22:41 #535947 by wireman
Ive been sweating copper for a living on/off for last 30 years,copper is not steel cooling it off with water doesnt hurt it like it does steel.
Although people have been tempering steel in brine/salt water since long before either of us were around. B)
15 Jul 2012 00:23 - 15 Jul 2012 00:23 #535984 by pig9r
wireman wrote: Ive been sweating copper for a living on/off for last 30 years,copper is not steel cooling it off with water doesnt hurt it like it does steel.
You're right, i wasn't thinking, nonferrous, so same result either way.
Last edit: 15 Jul 2012 00:23 by pig9r.
15 Jul 2012 09:04 #536024 by LarryC
Replied by LarryC on topic 2 questions
If your copper washers are only copper clad [coated with but not made of copper] then Annealing them is a waste of time.
You have two options. Toss them and get new ones or lightly sand them and spray them with copper coat. You could even use a dab of engine case sealer on them.
Larry C.
