Home machining questions
- APE Jay
Re: Home machining questions
11 Jun 2006 21:21
wireman wrote:
[/quote] quarter of a million dollars in machines?they spent that much on jays personal bathroom! :S :whistle: :woohoo:[/quote]
Actually, in our new building that we are doing at Willow Spring Raceway
www.aperaceparts.com/move.html
The bathroom in my office has a shower that is bigger than anything I have ever had in a house. My office with it's bathroom is all my wife's doing. She designed it as the office she thinks I deserve after 32 years of doing this stuff.
Steel, as for working for APE, keep an eye on our home page for a forthcoming "employment opportunities" link. You just never know.
Jay
Jay
- wireman
11 Jun 2006 21:39
wow!
if ya ever decide ya need a personal retired licensed plumbing-electrical contractor-coffee maker on the payroll let me know,will work for motorcycle parts!:woohoo: :woohoo:
- BSKZ650
12 Jun 2006 05:17
what kind of mill are you using? does it have a power feed?
I would spring for the fine bore head I think criterion, maybe spelled wrong, has one of the best out on the market.
77 ltd1000, current rider
76 kz900, just waiting
- steell
- BSKZ650
12 Jun 2006 09:47
thats the one, I dont think I would do a ebay, I would be worried about getting a damaged unit, it dosent take much to screw up a fine boring head.
I think you could mount the head by placing some blocks under the valve cover surface and use two steel rods thru the cam bores bolted down to the table
- solomrus
12 Jun 2006 10:10
www.lathemaster.com/BORINGHEADSETM3TSHANK.htm
that one isn't too bad.
more products at www.lathemaster.com
i've ordered a couple things from him, he's a really cool guy to work with.
--r
--r
198o kz1ooo Bravo Four
- flht1997
12 Jun 2006 10:35
i had some pictures on the old board from when i milled my 400 head. all i did was place the valve cover surface on the table and used t nuts right by the spark plugs. i do not know if it will work with the four's though. you may want to check clearance issues before you mill, i managed to go to far in the name of compression and made scrape out of one of my 400 heads
pic is what i have in my room at school, many kz parts have been strapped to that in the past few years
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- APE Jay
12 Jun 2006 11:14
steell wrote:
That one is way too small. You would need , at least, the #DBL-204E which takes a 1" boring bar. It sells for $434.00 and the shank is another $50.00.
Jay
Jay
- steell
12 Jun 2006 14:14
I just finished milling the head, I used four step blocks and four clamps to clamp over the cam valley on a 750 twin head. I had planned on taking .030" off, but I was taking .005 cuts and it took me nine tries to get it right, so I ended up taking .045 off
Looks like I could take off another .015 or so, but I'll try this head first and see how it works.
I have at least 3 or 4 more spare heads, so I can afford to ruin a couple, and probably will since I have never used any kind of mill before :laugh: :laugh: :laugh:
- 77KZ650
12 Jun 2006 15:15
steell wrote:
how much of a compression bump should that make?I ended up taking .045 off
07 MDP Rookie of the Year
- steell
12 Jun 2006 16:14
77KZ650 wrote:
Stock is 8.5:1
I don't know, but between removing the .045 and the .040 overbore it may be more than the starter will handle. I'm guessing ~10:1 but I might cc it to find out (but then again I might just stick it together and see what happens)steell wrote:how much of a compression bump should that make?I ended up taking .045 off
Stock is 8.5:1
- les holt
13 Jun 2006 01:32
Why dont you just make a tooling plate. 1/2" would probly work but I would suggest 1" thick aluminum. Using you cam cap bolt holes, bolt the plate to the head, then just bolt to mill table. If your using an older and possibly worn mill, watch out, you may think that babys flat but it WILL HAVE A CROWN IN IT from end to end. I know this is true, not from machining heads on mills but from twisting handles for over 22 yrs. As for the boring head cost and quality, I have seen some of the nicest stuff create junk and junk create some nice stuff. A machine is only as good as its operator. Setup is one of the most important parts of a good maching job. Be creative and just about anything can be done. Iv'e seen parts held down crazy glue for light machining and chains with turnbuckles for some awkward big parts.
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
