Home machining questions
10 Jun 2006 18:43 #53502 by steell
Home machining questions was created by steell
Ok, it's my turn :)
This question is addressed to those who have a machine shop in their garage/basement/bedroom/whatever, and we'll just ignore those who say it can't be done or think we are idiots :D
Number one: I'm new at the machining thing.
I'd like to know what you use to lock the cylinder head on the mill table? I don't have a vise large enough, and can't clamp it on the top because I'm using a flycutter.
Second question is, do you use a plate on top of the block to prevent the liners from moving when you bore the cylinders on the mill?
APE Jay/etc can just skip answering, nothing personal but I'm not about to spend the bucks (that I don't have anyway) on a Sunnen or Van Norman boring bar, I'm not working on anyone else's motors, just my own stuff (and I have spares) :)
Anyone have a decent adjustable hone they can sell cheap :D :D
Oh yeah, before people start complaining, I have an 80 KZ750 twin (but I'm also building a GPz750 motor or two). :evil: :evil:
Post edited by: steell, at: 2006/06/10 21:46
  • Pterosaur
  • Visitor
10 Jun 2006 18:56 #53509 by Pterosaur
Replied by Pterosaur on topic Home machining questions
If I may ask, what exactly are you trying to *do* to the head?
(....and if you say "mill the head", you're first on my list when I take over here...) :evil:
...it'd help get a grip on how to answer...
10 Jun 2006 19:14 #53519 by arobsum
Replied by arobsum on topic Home machining questions
well, with a car engine they bolt torque plates to the block while they machine it, might be something similar
when they bore/hone out bike blocks. not sure.
  • Duck
  • e vica na i sau na ga
10 Jun 2006 19:41 #53532 by Duck
Replied by Duck on topic Home machining questions
have not tried but...how about
loctite the jugs in
all you'll need is a plate for bottom of block and a mess of clamps to get it square and rigid
  • Pterosaur
  • Visitor
10 Jun 2006 20:35 #53560 by Pterosaur
Ever seen hard rubber expansion plugs?
Lay up the cylinder block on a set of machined steel spacer blocks to give clearance for the bottoms of the liners, insert the expansion plugs into the bolt holes, and bolt the whole mess to the mill table with 1/4-20's...
10 Jun 2006 21:21 #53579 by steell
Replied by steell on topic Home machining questions
Mounting the cylinder block to the table is no problem (T-nuts, step blocks, studs and clamps), I'm just wondering about the possibility of the liner moving around and whether I need to make a top plate to clamp the liners into the block.
I'm using a flycutter to surface the head, problem is mounting it since I need pretty much the entire surface clear. Might be able to find four places to clamp it though, have to take another look.
Some people bore small engine blocks on a lathe, while a twin would probably be do-able, a four would be a little more difficult unless you have a big honking lathe with 20" of cross slide travel, and my garage ain't big enough for one of those :D
  • Pterosaur
  • Visitor
10 Jun 2006 22:00 #53595 by Pterosaur
Well, one question to be asked is if the cylinder has ever been re-lined. Factory liners tend to be pretty snug.
If not, I'd think that accurate spacer blocks equal to the dimension between the bottom of the cylinder and the bottoms of the liners would do.
I'd think that a flycutter would exert more torque on the liners (attemping to rotate them within the block) than compression (trying to force them down and out).
Yeah, it'd be kind of tough to "fly" a flycutter between all those clamps...
10 Jun 2006 22:50 #53603 by steell
The flycutter is for surfacing the head, I'll either use a boring bar or boring head to bore the block. I have been thinking about getting a micrometer adjusting boring head, but it would be cheaper to just make my own boring head.
  • Pterosaur
  • Visitor
10 Jun 2006 22:57 #53604 by Pterosaur
Silly me. I read you wrong.
It's late, I'm bleary-eyed with trying to stay one step ahead of the lynch mob in the other thread and still take the odd pot-shot at a couple of others...
I'll be better in the morning....:blush:
  • APE Jay
  • Visitor
11 Jun 2006 15:33 #53732 by APE Jay
Replied by APE Jay on topic Home machining questions
Well if I were you.... Oopps, never mind:laugh:
Jay
11 Jun 2006 19:43 #53787 by steell
Jay
No sense in me arguing with a guy that has access to a quarter million dollars worth of tools and machinery, I'm a poor man that can't even afford to look at stuff like that :laugh: :laugh:
But if you want to send a five axis CNC machining center to me, I'll figure out how to run it :laugh:
APE is one of the places I'd almost pay to work at :)
Post edited by: steell, at: 2006/06/11 22:46
  • wireman
  • Visitor
11 Jun 2006 21:06 #53808 by wireman
Replied by wireman on topic Home machining questions
steell wrote:
Jay
APE is one of the places I'd almost pay to work at :)<br><br>Post edited by: steell, at: 2006/06/11 22:46
quarter of a million dollars in machines?they spent that much on jays personal bathroom! :S :whistle: :woohoo:
