- Thank you received: 8
Compression test question
- Medina
10 Jul 2012 08:01 #535015
by Medina
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
Compression test question was created by Medina
Valves adjusted, still an annoying ticking sound, not that loud, but at idle its there, seems to go away around 2k.....
but, the question oh wizened ones, comp test one cylinder is 140, the others are 150, any real danger in highway driving? Want to finish the year before I tear it down.
thanks
thanks
Medina, Oh
My Bike Thread
- faffi
- Thank you received: 36
10 Jul 2012 08:23 #535018
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic Compression test question
Compression is excellent, nothing to worry about.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- Medina
10 Jul 2012 08:38 #535020
by Medina
Medina, Oh
My Bike Thread
Replied by Medina on topic Compression test question
Thank you sir.
Medina, Oh
My Bike Thread
- Thank you received: 797
10 Jul 2012 10:26 #535040
by 531blackbanshee
Replied by 531blackbanshee on topic Compression test question
i would not be alarmed by a 10psi difference.
40psi yes,
40psi yes,
- steell
11 Jul 2012 19:35 #535321
by steell
Replied by steell on topic Compression test question
Ticking sounds usually turn out to be exhaust leaks.
- Medina
12 Jul 2012 02:03 - 26 Jul 2012 12:35 #535390
by Medina
Medina, Oh
My Bike Thread
I'm thinking its got to be exhaust, I ran tonight for an hour, without my helmet, not a fan of that. But it sounded like the front left...for a while, then the front right, or middle.
I'll just get new biscuits and swap them out.
thanks
followup, I switched those half orings to different cylinders and now the ticking has moved to #4...
its not as bad, but its one of those things.
someone suggested just remove. reinstall, retorqueing
thanks
Medina, Oh
My Bike Thread
Last edit: 26 Jul 2012 12:35 by Medina.
