- Thank you received: 1616
kz550 clutch problem....?
- loudhvx
12 Jul 2012 22:14 #535525
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic kz550 clutch problem....?
Bike in gear, clutch pulled, will still have plenty of drag unless the plates and disks are new. As they wear together, they tend to want to hold each other more. Sometimes you can fix that by scuffing up the plates with 220 grit, so they are not so shiny, but usually it's not a problem to warrant worrying about. As it gets hotter outside, and the oild gets thinner, they tend to want to stick together more.
If the bike sat for many years, and the plates are rusty, then you will notice they don't want to release all the way, nor will they want to grab all the way. Then it's time to take them out and sand them or replace them.
Be very careful with torquing the basket bolts. They like to snap off.
1981 KZ550 D1 gpz.
Other links.
- joshjones84
13 Jul 2012 15:14 #535684
by joshjones84
82 KZ550 LTD
Replied by joshjones84 on topic kz550 clutch problem....?
this may sound dumb but.... could i put seafoam in my crank case? would that clean the clutch?
82 KZ550 LTD
- loudhvx
13 Jul 2012 15:58 #535697
by loudhvx
1981 KZ550 D1 gpz.
Other links.
No. I don't know if seafoam is meant to go into crankcases, but I certainly wouldn't do it. It's not really a matter of dirt. The plates are just polished together.
I think you will know whether it's a problem or not after you ride it. I wouldn't do anything with the clutch until then. It may need nothing.
1981 KZ550 D1 gpz.
Other links.
- apbling
- Thank you received: 12
05 Aug 2012 09:27 #540821
by apbling
Replied by apbling on topic kz550 clutch problem....?
+ 1 on the be careful about torquing the clutch basket bolts. The torque spec is in in-lb, not ft-lb....found that out the hard way.
- OldSchoolZ
- Thank you received: 33
05 Aug 2012 13:01 #540842
by OldSchoolZ
Remember, don't work on your bike so much you never ride it.
Replied by OldSchoolZ on topic kz550 clutch problem....?
Sounds like the clutch plates are stuck together too tight. Either physically pull plates apart from each other with clutch cover off or work throttle in top gear riding with clutch pulled in. Stuck clutches can be a pain in the azz.
