kz550 clutch problem....?
- joshjones84
82 KZ550 LTD
- apbling
- Thank you received: 12
I do think your mechansim is binding up though. It can be tricky sometimes getting that thing just right.
- osage
- Thank you received: 4
I just put a cable on my 82 yesterday. I had an issue with adjustment because I forgot to look a the FSM suppliment for that model. I turned the adjustment screw on the cover the wrong way for an 82. I was lucky and no damage the threads. I was able to get it back together. I should have keep track of how many times I had the cover off.
1976 KZ750B1
1982 KZ750H3
- joshjones84
82 KZ550 LTD
- apbling
If it had the cover off, it might be worth taking a peak at the clutch basket too to see if something isn't funny in there.
- joshjones84
82 KZ550 LTD
- Thank you received: 1656
- joshjones84
82 KZ550 LTD
- Thank you received: 2098
joshjones84 wrote: i have a brand new adjusting screw and brand new clutch cable. i believe im going to have to get a new adjusting screw because mine is all chewed up. i can only turn the nut a tiny bit and its not enough to turn the adjusting screw. any clue as to where i can pick a new adjusting screw?
Adjusting screw is part no. 92009-1009 available at Kawasaki dealerships.
See link in my signature as to using kawasaki.com.
- joshjones84
82 KZ550 LTD
- joshjones84
reason i ask is because my back tire drags a little bit. i dont know when the bike has been rode last. it could have been setting around for 10 years for all i know.
82 KZ550 LTD
