carbs
- Landon22
06 Jul 2012 03:23 #534196
by Landon22
carbs was created by Landon22
I need help on cleaning my carbs for my 1983 kz550. i need all the help i can get. thanks
- bountyhunter
- Thank you received: 337
06 Jul 2012 04:13 #534198
by bountyhunter
Replied by bountyhunter on topic carbs
As a first step to try to avoid a complete teardown:
Clean the tank and petcock.
While the tank is off, remove the bowl drain crews and shoot some carb cleaner down the gas inlets of the carbs.
Replace the screws and fill each carb with Gumout liquid or Seafoam or whatever carb cleaner. Plug the inlet and let it sit a couple of days and remove the drains and rinse down again with carb spray.
This will get most dirt out.
- Landon22
06 Jul 2012 16:54 #534285
by Landon22
Replied by Landon22 on topic carbs
I cant really get the tank off because i dont know how. Is there a diagram or anything?
- zig
- Thank you received: 1
06 Jul 2012 17:38 #534294
by zig
Replied by zig on topic carbs
take your seat off and look at base of tank you will see a bolt remove that bolt it conccect gas tank to frame remove fuel lines and tank should come off
- Landon22
06 Jul 2012 18:01 #534299
by Landon22
To take my seat off i need a key. Is they key the same for igniton and seat?
- mtbspeedfreak
- Thank you received: 36
06 Jul 2012 19:20 #534324
by mtbspeedfreak
2000 ZRX 1100
1976 KZ 900- Daily Driver
Replied by mtbspeedfreak on topic carbs
Should be the same key
2000 ZRX 1100
- Landon22
06 Jul 2012 19:21 #534325
by Landon22
Ok thanks alot ill try it
- zig
07 Jul 2012 13:08 #534497
by zig
how you make out
- loudhvx
- Thank you received: 1616
07 Jul 2012 13:15 #534500
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic carbs
There are no bolts on the 550A tanks.
You just lift up the seat, then pull up on the rear of the tank and it will pop out of its holder at the back. Then you pull the whol tank backward and upward to slid it out of the front holders.
Make sure the 2 hoses (fuel and vacuum) and wires(if any) are disconnected from the tank first.
1981 KZ550 D1 gpz.
Other links.
- pete greek1
- Thank you received: 185
07 Jul 2012 13:30 #534504
by pete greek1
Replied by pete greek1 on topic carbs
make sure petcock is in the OFF position before removing the fuel lines
- loudhvx
07 Jul 2012 13:34 #534505
by loudhvx
1981 KZ550 D1 gpz.
Other links.
The petcock is a vacuum type. There is no "off" position. "On" or "Res" is actually the off position when the motor is not running. "Pri" (prime) position will let gas flow all the time.
1981 KZ550 D1 gpz.
Other links.
- pete greek1
07 Jul 2012 14:00 - 07 Jul 2012 14:02 #534513
by pete greek1
my bad !! Loudhvx
Last edit: 07 Jul 2012 14:02 by pete greek1.
