OffSet Sprocket?
  • Sellitto42kz
  • Sellitto42kz's Avatar Topic Author
  • Sellitto
OffSet Sprocket?
05 Jul 2012 18:30
#534091
About to order my front sprocket- 1979 kz1000
530 conversion
05' gsxr 600 rear swingarm and 180tire (allstock)
anyone have this exact setup?
from my research its a 5/8th but WANT TO ME 100%
thanks guys
  • MFolks
  • MFolks's Avatar
Re: OffSet Sprocket?
05 Jul 2012 18:35
#534093
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Jul 2012 19:01 - 05 Jul 2012 21:02
#534104
u must measure the offset your self. dont go by someone elses project. it will likely be 1/2" or 5/8" but check it yourself so u dont have to buy a second 1. it depends on your individual set up. Porche used a 1 1/2" offset on his. ;)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 05 Jul 2012 21:02 by mark1122.
  • MFolks
  • MFolks's Avatar
05 Jul 2012 19:07
#534105
You might need an additional bearing to support the drive sprocket, and probably machining on the case for clearance.
  • Sellitto42kz
  • Sellitto
05 Jul 2012 19:12
#534107
ok thanks guys-
best way to messure it?
  • MFolks
  • MFolks's Avatar
05 Jul 2012 19:23
#534109
Usually a long straight edge placed on the rear wheel sprocket, lined up with the engine sprocket gives you an idea of what has to be moved. The chain must run as straight as possible to avoid bending, as this greatly increases the wear on the side plates, rollers and pins.
A machinist's 6" ruler(sometimes called a scale)can be used to measure to offset from the straight edge.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
05 Jul 2012 19:37
#534110
just make sure the rear wheel is parralel to the front wheel first.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Derigo
  • Derigo's Avatar
05 Jul 2012 20:38
#534117
yes I do
Attachment corbinseat001.jpg not found
  • Derigo
  • Derigo's Avatar
05 Jul 2012 20:40
#534118
5/8" off set
  • Sellitto42kz
  • Sellitto
05 Jul 2012 21:44
#534127
Derigo LOVE the bike man seats looks nice-
if youve got to ride the bike LMK how it handles because im Very excited about it-
ive noticed i bit of a gap will do for the front not much at all but i want it to be perfect-
ill order the 5/8th see how it fits-
thanks again guys love the positive feed!++
The following user(s) said Thank You: Derigo
  • Sellitto42kz
  • Sellitto
05 Jul 2012 21:46
#534128
also did u use the rubber chain guide that comes on the gsxr? it would fit wit the far ID an the swingarm.. i tried to cut it to make it work but said fuck it an it was snug anyway-- LMK
  • z1kzonly
  • z1kzonly's Avatar
05 Jul 2012 22:17
#534133
Hey New Guy, Nice stuff! you know your stuff!
About 2-3 years ago there was a guy on here called "irishwill" he made up about a dozen of these offset bearing plates. They were made for 5/8" offset sprockets He "irishwill" does excellent work.
But you should try and find one of these plates from a dragbike style bike to use.
Irishwill was out of Canada, I paid him only $100 dollars and he shipped this plate to me.
And I bought a new PMI sprocket at dealer cost for $69 bucks.
I had this project laying around, gonna play with it someday?
I tried selling the rolling chassis for $500 on ebay, no one bought it!
But do something like this.
Good Luck, keep tinkering!
