- Thank you received: 391
Engine over heating
- Motor Head
You say it only runs 2 minutes then tries to shut off? Again, are you running a fan to move air over the motor when sitting still? The smoke off of the external, that should burn off in a few minutes, that should be left over from working on it, unless you have a leak somewhere. Look at your spark plugs, are they white still or getting colored, especially in the cylinder that got holed. Maybe see if you have some vacuum leaks, around the carb manifolds, or the vacuum hoses. I'd be pulling the carbs and going through them, something had to lean out, probably to hole the piston. What set up are you running? Stock?
- wireman
- Thank you received: 299
what are the other symptoms ,where is it idling?
- green
- green
- green
Attachment 002.JPG not found
Attachment 003.JPG not found
Attachment 001_2012-07-01.JPG not found
Just checked plugs, they look fine!
- green
- green
- green
- Motor Head
Valve timing uses the "T" which is Top Dead Center, the Ignition uses the "F" which is for Fire.green wrote: Hey Patton, set the valve timing with the cam at the F mark? not the T mark?
- Motor Head
- green
- green
[attachment:1]C:\fakepath\timing_0003.jpg[/attachment]
[attachment:2]C:\fakepath\timing_0004.jpg[/attachment]
I`ve looked at the valve timing again, the book says one thing and my bikes gear pattern does not match up with the book. In the book it shows the exhaust Z7ex line straight with a peg, on mine the line splits the link, I made a diagram of the two, were do I start my count to 45th to 46th. or am I being too anal....
