Engine over heating
- green
Attachment 001.JPG not found
I have a `83 kz750 f1-ltd. It`s over heating, I put new rings in and a new piston on no.1 brought no. 1-4 to TDS and put the cams as per manual Z7EX level engine and IN level with engine with the 45th and the 46th pegs by the IN mark on the intake cam, both notches are pointing at the inside, The crankcase timing mark is dead on TDS, I`m about to give up, I`ve checked and rechecked every possible thing. How can I fix this mess? Also plugs are new and gaped at.07 THIS SUCKSSSSSS!
- Motor Head
- Thank you received: 391
- trianglelaguna
- Thank you received: 235
and what made you decide do this work to start with,bring us up to speed
going down the road overheating
sitting in a garage overheating
Motor Head wrote: How do you know it is overheating? What are the symptoms/ scenario? Are you running it sitting still, with out a fan to blow air over the motor?
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- green
- Motor Head
- green
- green
- Motor Head
The hole in the piston, have you rebuilt your carbs? Get the things all nice and clean, set fuel height, check jet sizes etc? ignition timing should be set at Idle to the 1-4 F mark. But should be checked for proper advance also. There should be marks father up on the rotor, around the 40 to 45 degree area, they're just lines no letters/ numbers. These should be lining up when revved, above 3K RPM.
- baldy110
- Thank you received: 512
- green
- green
- Thank you received: 2098
F mark alignment (not T mark)?
Advancer stuck in closed position?
