Stock ignition timing, 'safe' nitrous shot?
  • Denvgasm
  • Denvgasm's Avatar Topic Author
30 Jun 2012 20:44
#532865
What's the biggest shot of nitrous you can run in a KZ1000 engine that doesn't have the timing tuned? How big do you think you could go before you'd have to start upgrading internals? Just curious...
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Stock ignition timing, 'safe' nitrous shot?
30 Jun 2012 21:03 - 30 Jun 2012 21:03
#532875
Really??
Last edit: 30 Jun 2012 21:03 by 4TheKZ1000.
  • trianglelaguna
  • trianglelaguna's Avatar
30 Jun 2012 21:20
#532883
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Denvgasm
30 Jun 2012 21:35
#532885
Yes really. Will a wet 40 shot pop it?
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
01 Jul 2012 10:04
#533013
It may be allright for a very short burst but why try. It's a ton easier to pull some timing out than it is to tear the motor down to repair not to mention a butt load cheaper.
Les
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
01 Jul 2012 13:05
#533068
Be carefull. Use it sparingly or you too could have a custom artifact. No more than 2 second bursts. Or spend the money on building a rock tough motor
The following user(s) said Thank You: BlackZ1R, Denvgasm
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
01 Jul 2012 13:44
#533078
:laugh: Had a buddy bring me a head that looked a lot like that, wanted to know If I could weld it up. Bunch of spray and propylene oxide don't work well together.
Les
  • Moderator
  • Moderator
01 Jul 2012 13:53
#533084
Les , I figured on fixing this one with some J B Weld. :woohoo:
  • LarryC
  • LarryC's Avatar
01 Jul 2012 14:06
#533089
For starters, if you're using OEM pistons, you'll blow the ring lands off :)
Larry C.
  • Denvgasm
01 Jul 2012 16:12 - 01 Jul 2012 16:13
#533122
Getting MTC 1075 pistons soon, everything is rebuilt fresh, but no other aftermarket parts... Reason I asked about the timing is because I'm not prepared to sink the money into a big shot and the motor work that goes along with it, I just think it would be a fun novelty to be able to open up a small 30 or 40 shot for a few seconds every now and then. Not racing it or anything. Just wondering if I can do it reliably for fun. Also when it comes time to sell it'll be a little extra coolness factor for the potential buyer...
Last edit: 01 Jul 2012 16:13 by Denvgasm.
  • wireman
  • wireman's Avatar
01 Jul 2012 22:13
#533214
Whats been done to bottem side of motor? B)
  • Denvgasm
02 Jul 2012 01:44
#533243
Not a single thing...
