Drain plug under stator cover???
- drakewoodie
30 Jun 2012 02:10 #532737
by drakewoodie
1981 KZ550C - Kawasaki 550 LTD
Drain plug under stator cover??? was created by drakewoodie
Can anyone tell me what that drain plug is for? It is located directly below the stator cover.
- MFolks
- Thank you received: 540
30 Jun 2012 02:28 #532738
by MFolks
Replied by MFolks on topic Drain plug under stator cover???
Picture?
- mtbspeedfreak
- Thank you received: 36
30 Jun 2012 03:06 #532739
by mtbspeedfreak
2000 ZRX 1100
1976 KZ 900- Daily Driver
Replied by mtbspeedfreak on topic Drain plug under stator cover???
The rubber grommet that the 3 stator wires pass through?
2000 ZRX 1100
- Motor Head
- Thank you received: 391
30 Jun 2012 11:17 - 30 Jun 2012 11:19 #532774
by Motor Head
Replied by Motor Head on topic Drain plug under stator cover???
#18 Main Galley Plug? You'll see 2, one on each end, main oil galley plugs. Part of the machining process for making the oil galley. Screw in plugs won't have issues like soft/ welch plugs.
Last edit: 30 Jun 2012 11:19 by Motor Head.
- drakewoodie
01 Jul 2012 00:37 #532940
by drakewoodie
Replied by drakewoodie on topic Drain plug under stator cover???
number 18 on the drawing...thanks
