- Thank you received: 36
Possible valve float
- faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- Surfdude_007
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
- Motor Head
- Thank you received: 391
- LarryC
Larry C.
- Surfdude_007
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
- Thank you received: 2098
Ignore the T mark when setting the ignition timing.
For illustration:
Attachment advancerstyles.jpg not found
- faffi
Motor Head wrote: That picture actually shows the Ignition plate rotated With the direction or crankshaft travel, this is to Retard the timing. It maybe that it is adjusted as far as the slots would go, and still be to far advanced. Use a timing light to find out where the timing is set. Do you have a manual for the bike/ bikes?
My bad :blush: - of course it is! If timing should be set closer to full advance, the severely retarded timing will rob the engine of power at revs above 4000 rpm quite substantially.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- Surfdude_007
1980 KZ1000 B4 LTD
1982 KZ1000 LTD
