- Thank you received: 12
Stuck 1974 KH 400 3 cylinder 2 stroke motor
- oldkaws4ever
- Have no regrets...... You only live once.
28 Jun 2012 04:53 #532308
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Stuck 1974 KH 400 3 cylinder 2 stroke motor was created by oldkaws4ever
Hey guys, my buddy just dropped of a 1974 kawasaki kh 400 3 cylinder 2 stroke with a little over 12,000 miles on it. The motor is locked up on it, any tips on getting it free?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- faffi
- Thank you received: 36
28 Jun 2012 06:10 #532311
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic Stuck 1974 KH 400 3 cylinder 2 stroke motor
You can remove one cylinder at the time and see which one that's stuck. Heat that cylinder and spray cooling gas on the piston once the cylinder is warm - this can break it free in many cases.
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- Kitten Tooth
- Thank you received: 10
28 Jun 2012 08:53 #532333
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic Stuck 1974 KH 400 3 cylinder 2 stroke motor
I use a 50/50 mixture of Acetone and transmission fluid to break bolts loose on lots of stuff. Had stuck brake bleeder screws and basically all the mounting bolts that have anything to do with the brakes on my Ford F-150. squirted some of the mixture on said bolts, let it sit over night, and the next morning they broke loose and turned right out. Im fairly certain this mixture wont hurt aluminum (i think pistons are made of aluminum). try pouring a mix of this into each of the cylinders and let it sit a few days. All else fails, start jumping on the kickstarter (don't do that) hahaha.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- oldkaws4ever
28 Jun 2012 09:24 #532338
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Stuck 1974 KH 400 3 cylinder 2 stroke motor
Ill give it a try kitten tooth, i have heard the the kh 400's are screamers, i cant wait to take it for a ride !!!!
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Motor Head
- Thank you received: 391
28 Jun 2012 10:09 #532339
by Motor Head
Replied by Motor Head on topic Stuck 1974 KH 400 3 cylinder 2 stroke motor
What no pictures of the Bike?
Probably stuck the center cylinder, not very many cooling fins on the center. Pretty quick bikes in a straight line though. They're pulling a bit of change if in good shape and running.
- oldkaws4ever
28 Jun 2012 12:13 #532350
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Ill snap some pics of it today, it is straight out of the 70's with artwork air brushed on the tank, its way cool.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Kidkawie
- I bleed premix
- Thank you received: 245
28 Jun 2012 13:57 #532374
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic Stuck 1974 KH 400 3 cylinder 2 stroke motor
I've used Marvel Mystery oil to free up engines.
I think the triples guys run fatter jets on the center cylinder to help keep it cool.
1975 Z1 900
2004 KX125
- oldkaws4ever
28 Jun 2012 14:17 #532380
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
I have a lot of it laying around, ill pore some in and let it soack. The carbs are locked up too, ill have a look at what jets are in it when i get them torn apart.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
28 Jun 2012 14:27 #532383
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Do you think it would be better to pull the head off, or pour it down threw the plug holes?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Kitten Tooth
28 Jun 2012 18:14 #532428
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
try the chemicals we listed. I have seen marvel mistery oil free up a 78 KZ750 twin that sat in the woods with a missing plug for a few years. +1. try the mystery oil down a spark plug hole. If that dont work then try the 50/50 mix i posted. if neither work then start tearing the motor apart. I love then 2 stroke KH400s heres a cool video i found of one.
i found one in Sioux city with a Denco S pipe and another that was 100 % stock. 600 for each of them. too bad i passed it up. I didnt have a job
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
28 Jun 2012 18:16 #532429
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
and hopefull the carbs are just full of Pancake syrup i took the ones off of that KZ750 i mentioned and it looked just like they were full of that. Some carb cleaner did the trick
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- oldkaws4ever
28 Jun 2012 18:18 #532430
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Now i want to find chambers for it. lol. I poured marvel mystery oil down the plug holes, im gonna leave it set for a few days and see what happens. Il post the pics later on.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
