Oil Breather
- AjKZBobber
- New KZ rider...Long time dirt biker
26 Jun 2012 04:36 #531816
by AjKZBobber
1979 kz750 b4 twin bobber
Oil Breather was created by AjKZBobber
So, I have pod filter on my 1979 KZ750 twin. Since there is not an air box anymore, the Oil breather is just open to atmosphere, instead of being routed to the air box that is no longer in place.
My question is whether or not this is the right thing to do with the Oil Breather. Should it be blowing to atmosphere? Should I maybe add a hose to it, and route it so that it blows away from the bike instead of straight up underneath the carbs?
- Thank you received: 2098
26 Jun 2012 06:24 - 26 Jun 2012 07:34 #531824
by Patton
Oem connection to the air box may afford a slight vacuum to assist exit of blowby from the crankcase.
Akin to the Brit bike practice of routing via a hose alongside the rear fender, and being less sophisticated, absent the "recycle" feature.
There's also the mini-pod option, which might under certain conditions help prevent entry of insects and small vermin.
Replied by Patton on topic Oil Breather
Attachment crankcaseventhose.jpg not found
Last edit: 26 Jun 2012 07:34 by Patton.
- Thank you received: 2829
26 Jun 2012 08:46 #531837
by 650ed
Replied by 650ed on topic Oil Breather
On my BSA there was a stubby little tube that pointed directly at the countersprocket so oil mist would keep the drive chain lubed. Ed
- Medina
- Thank you received: 8
26 Jun 2012 09:04 #531840
by Medina
Genius
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
Replied by Medina on topic Oil Breather
650ed wrote: On my BSA there was a stubby little tube that pointed directly at the countersprocket so oil mist would keep the drive chain lubed. Ed
Genius
Medina, Oh
My Bike Thread
- AjKZBobber
27 Jun 2012 17:03 #532137
by AjKZBobber
Took this advice and ran with it. Thanks for the info and the inspiration.
Replied by AjKZBobber on topic Oil Breather
