- Thank you received: 4
oil pressure light on at 1800RPM and below?
- richrand
- MFolks
- Thank you received: 540
When you had the pan off, did you check the oil pump for wear?
- DiamondSkyBlue1000
- Thank you received: 40
- richrand
I did not touch the pump. Since this wasn't a problem beforeI figured that it was fine. I don't have a low pressure gauge. I'm planning on pulling the sump off again to get a better seal. Went back to check out a few things and light would come on at about 1500RPM and turn off above that.
- faffi
- Thank you received: 36
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- Thank you received: 2829
richrand wrote: I've got my bike back together and running. The oil pressure light is coming on ~1800RPM and below and turns off at ~2000RPM and above. The sump was removed and reinstalled with a new filter and OEM gaskets but is leaking a good bit. I'll pull it off and reinstall with RTV to stem the leaking. Could this be causing the low pressure at the lower RPM range? It worked fine before draining all the oil. Any thoughts on what I should check? Thanks.
"...I'll pull it off and reinstall with RTV to stem the leaking...."
Did you use RTV or some other such stuff when you assembled the engine? Could it be that some of that muck broke loose and is clogging up your bike's oil flow? Ed
- baldy110
- Thank you received: 512
- LarryC
baldy110 wrote: DO NOT USE RTV, the pan will seal with just the gasket. It's been said before but make sure everything is clean and all old RTV is off. RTV breaks free on the inside and gets into all sorts of places it shouldn't.
X2
You didn't by some chance forget to install the big o ring on the pan did you? That will definitely cause that particular problem.
Larry C.
- richrand
- richrand
X2
Argh FML! Thank you, Larry. This is exactly what I didn't do. Will do this today.
