oil pressure light on at 1800RPM and below?
- Kitten Tooth
Re: oil pressure light on at 1800RPM and below?
26 Jun 2012 07:22
Yea i was gonna say, when my 76' Ford LTD is even half a quart shy on oil (DAMN YOU WORE OUT REAR MAIN SEAL!!) I get a collapsed lifter if i go above 70 miles per hour. Low oil pressure friggin sucks
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- LarryC
26 Jun 2012 07:51richrand wrote:LarryC wrote:baldy110 wrote: DO NOT USE RTV, the pan will seal with just the gasket. It's been said before but make sure everything is clean and all old RTV is off. RTV breaks free on the inside and gets into all sorts of places it shouldn't.
X2
You didn't by some chance forget to install the big o ring on the pan did you? That will definitely cause that particular problem.
Argh FML! Thank you, Larry. This is exactly what I didn't do. Will do this today.
You're Welcome
Larry C.
