- Thank you received: 20
cam plugs moved in
- nads.com
23 Jun 2012 15:34 #531267
by nads.com
cam plugs moved in was created by nads.com
My cam plugs are almost inside the engine.
Could it be the loose valve seals I have are
vacuuming the crankcase? They have a lip on the
outside and I can't see why they would slide inward.
Cept for the fact the motor is mighty, and mean?
The vacuum is more powerful than the almighty
black hole?
I'm just trippin and none of what I say is really happening?
I repeat myself constantly and none of what I say makes sense
so why should this?
Help me out here, you all know I need it. :whistle:
zx6 stand down
R6 stand down
Cbr stand down
r1 better be be quick on the throttle too things happen out there...
If your not ready, I will be.
Just get me out ahead, that's all I need. And try to catch me.
You'll have to work for it and there is no quarantee.
Just another payment due.
Now over to Ricks to build his mopar 360, crank in last night,
Keith blacks go in and heads, then it's cam timing 101.
Gotta help a brother out...
Gotta say boo yaa!
knoe bodee knows.....
black hole?
so why should this?
zx6 stand down
R6 stand down
Cbr stand down
Gotta say boo yaa!
- bountyhunter
- Thank you received: 337
23 Jun 2012 15:37 #531268
by bountyhunter
Replied by bountyhunter on topic cam plugs moved in
My 750 twin isn't mighty or mean, but it still sucked one of the new Kawi camplugs I installed inward just like yours. We should put up a sticky on this saying how to install them so they hold position.
- Thank you received: 2829
23 Jun 2012 20:00 - 23 Jun 2012 20:07 #531323
by 650ed
Replied by 650ed on topic cam plugs moved in
When Kawasaki designed the KZ650 engine they eliminated the problem of cam plugs being spit out or sucked in by running a cam cover bolt through the center of each plug (see pic). Is there enough metal on your engine’s cylinder head and cam cover to perhaps drill a small hole in the top of the head and bottom of the cam cover and install a thin roll pin running between the 2 holes and through the cam plug? This should keep the plug from moving out of position. Ed
Attachment CamPlugs.jpg not found
Last edit: 23 Jun 2012 20:07 by 650ed.
- faffi
- Thank you received: 36
24 Jun 2012 07:08 #531393
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic cam plugs moved in
Fark, your machine is immaculate, Ed :woohoo:
Sorry, as you were
Sorry, as you were
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- pete greek1
- Thank you received: 185
24 Jun 2012 12:20 #531430
by pete greek1
Replied by pete greek1 on topic cam plugs moved in
Ed ,just likes to fool us all, by posting pics. of his bike from the day he bought it in 1977 :lol: !!!!
- Jonny
- woot!
- Thank you received: 22
24 Jun 2012 13:34 #531441
by Jonny
A little known fact about Ed himself, is that he also appears exactly as the day he did when purchasing this particular 650 in 1977... Through some combination of black magic, and the power of Kawasaki. :woohoo:
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
Replied by Jonny on topic cam plugs moved in
pete greek1 wrote: Ed ,just likes to fool us all, by posting pics. of his bike from the day he bought it in 1977 :lol: !!!!
'78 KZ 650C2 'Lila'
- faffi
24 Jun 2012 13:38 #531443
by faffi
1977 KZ650B1
1980 F1 engine
B1 Points ignition
:silly: :lol:
(No KZ ever looked that bright when they left the factory )
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- nads.com
24 Jun 2012 16:59 #531462
by nads.com
Replied by nads.com on topic cam plugs moved in
Thanks!
