- Thank you received: 20
need advice bringing zx6 back to life!
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
Today I drained the gas out of the tank -- smelled a bit like varnish.
I drained the tank and am flushing it with lacquer thinner to dissolve the old gas inside.
This is a 1995 zx-6r and it looks like a major deal to get at the carbs!
The carbs stick up nearly vertical and to me, it looks like I can remove the carb float bowls because of the carbs' near-vertical orientation.
Can I squeak by just by pulling/cleaning the bowls and jets and save the trouble of removing a "hassle's worth" of airbox/hoses/yada yada?
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- jeffasaki
- Thank you received: 44
both blew crank bearings
one a 92 the other a 95
these bikes are intrinsicly weak on the bottom end
you have a set of downdraft 36mm keihin cv carbs
every zx600 ive ever seen has had bottom end failure at one point
if your gonna bring it back to life
drain the oil
change the oil filter
drain and change the coolent
youll have to remove the carbs and clean em
sorry
when you get it back together be very careful
never rev this motor until its been warmed up
and i mean warm good and warm
itll probably blow up anyway
absolutely the worst bike ever to come from kawasaki
seen too many people blow em up
it happens every time
and every time its from people that rev the shit out of em before theryre warmed up
just my 2 cents worth
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- newOld_kz1000
I couldn't pass up this bike, I usually buy 70s KZs but I once owned a '93 zx-7 and this '95 zx-6 looks so much like it.
Plus the specs on this zx-6:
105hp
400 lbs dry weight
Man oh man. That's hot for a 52-year-old guy like me. Maybe too hot.
The other reason I bought it is -- the first owner was afraid of it.
This 105hp lightweight beast was the first motorcycle he ever owned in his life.
No way is a hot beast like this a good 1st bike for a new rider! Good gawd.
He was 24 when he started riding and bought this -- this is not a beginner bike.
The seating position alone is not good for someone who's never ridden before.
It has only 3300 miles on it and he stopped riding it soon after buying it
and it's been in his garage ever since -- it looks show-room new.
Like a time capsule.
Those factors have me hoping the bottom end is okay but I'm still gonna be super cautious,
and thank you for letting me know about the bottom end problem, I would otherwise never have known.
- jeffasaki
and can last a good long time
as long as you know that its a race engine
yes they do make horsepower
but make sure that you have it up to operating temp
before you open er up
IF you know what youre doing and understand what the bike is capable of
youll have a good old time with it
IF!!!! you start it up and try to outrun smokey then youll pay the price
you sound like you know what youre doing so heed the advice
once warmed up these little 600s are a joy
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- newOld_kz1000
Old Man Rock wrote: Not sure how compatible but here's a 2005 Manual I used for my build....
zx-6r-2005-service-manual
Thanks OMR, I do need a manual. Unlike a kz1000 or kz550, this is not as straightforward to get at stuff. I'll have a look in that manual to get an idea about the ins and outs of the airbox removal.
One thing I did notice -- even though this is not a fuel-injected bike, it has a fuel pump.
I see what looks like a stock, designed-to-be-there fuel filter just before the gas enters the fuel pump -- is that indeed a filter or screen and do I need to pull it and clean it or replace it?
- jeffasaki
ill never use em
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- newOld_kz1000
Very very gracious of you to offer. I feel it's more important to get them to
someone who will use them, but I am very grateful for your offer!
Somebody on the board here can use those. Thanks again Jeff!
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- jeffasaki
who wants em?
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- newOld_kz1000
Old Man Rock wrote: Here ya go....
1995-1997 Kawasaki ZX-6R Service Manual
That did me, thanks OMR I verified in the manual that indeed there's a stock inline fuel filter just in front of the fuelpump. Normally a 3300 mile bike probably wouldn't need one but I'm inclined to put a new filter in there due to the old gas. He put it away wet. The cool thing about the fuel pump though, compared to my standard fare of 70s vintage machines -- the pump probably prevents fuel from getting to the cylinders during storage if the petcock is leaky (and he did say the petcock was leaky a bit).
OMR I appreciate your help with the shop manuals, thanks man.
