- Thank you received: 4
no compression on revalved head?
- richrand
- Motor Head
- Thank you received: 391
- richrand
Motor Head wrote: You say you put some valves in. Please expend on that a bit, did you use new valves, or grind the old ones you had? Did you check the guides, and cut the valve seat angles? Did you check for install height? Check the valve clearance to camshaft? Etc.
All new valves (but spec for a 1976 not a 1977). I did not check the guides or cut the valve seat angle. I also did not check for install height as I believed these would be OEM spec. I did not check for clearance. Just put them in and put it back together. Being honest here. I need advice. Thanks.
- Motor Head
Do you have a manual for your bike, as it is necessary for the specs and procedures. Best to leave such work to a qualified machine shop.
you can take off the valve cover and check the valve clearances, you will find that they are tight, probably. Adjusting them may gain some compression.
- richrand
Motor Head wrote: You will be pulling the head back off I would for sure. These things need to be done correctly for it to work, let alone last.
Ok. i'll pull the cover off tomorrow and check the clearances. I do have a manuel. Thanks.
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
1979 kz 1000 06 katana 750
- Tomolu5
- Thank you received: 45
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- wireman
- Thank you received: 299
- Thank you received: 2098
- APE Jay
- Banned
- Thank you received: 58
- bountyhunter
- Thank you received: 337
- bountyhunter
Or the mickey mouse version I used: flip the head over and fill the valve pockets with very thin oil and see if it leaks past the valves. You can take motor oil and thin it with mineral spirits.APE Jay wrote: Before you put it back on the next time, vacuum test it. Most top head shops have a vacuum tester.
