kz1000 72mm which gasket/sealant to use
- vintkaw77
18 Jun 2012 20:58 #530204
by vintkaw77
kz1000 72mm which gasket/sealant to use was created by vintkaw77
Which is better fiber or aluminum base gasket? Any sealant techniques to follow?
- bountyhunter
- Thank you received: 337
19 Jun 2012 03:49 #530283
by bountyhunter
Replied by bountyhunter on topic kz1000 72mm which gasket/sealant to use
The factory base gasket on mine was some kind of fiber type set on with a very strong adhesive similar to 3-bond type. It was very hard to remove.
When I rebuilt mine I made a base gasket from the 1/32" material from Auto Zone and sealed it with Ultra Black Hi Temp gasket sealer. Worked perfectly.
- wireman
- Thank you received: 299
19 Jun 2012 13:07 #530324
by wireman
Replied by wireman on topic kz1000 72mm which gasket/sealant to use
Fiber gasket is most common for base gasket,spray with copper coat before installing
