kz1000-Having trouble removing cylinder head
- vintkaw77
18 Jun 2012 13:26 #530090
by vintkaw77
kz1000-Having trouble removing cylinder head was created by vintkaw77
77 kz1000 engine bored to 1075cc under a 1000 miles, however need to remove cylinder head and its stubborn. Any suggestions? Prying is just enough to let oil seep out but not lifting the block. Should I position the pistons a certain way?
- StreetfighterKz
- Thank you received: 117
18 Jun 2012 13:41 #530092
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic kz1000-Having trouble removing cylinder head
What have you removed so far? You're going to have to remove the cams (hold up the cam chain with a wire or something) and remove all the head nuts including the two 6mm bolts by the #1 and #4 spark plugs.
Later, Doug
Later, Doug
1989 Vmax
- vintkaw77
18 Jun 2012 13:48 #530093
by vintkaw77
Replied by vintkaw77 on topic kz1000-Having trouble removing cylinder head
I've removed everything else. Now im ready to remove the cylinder head.
- bountyhunter
- Thank you received: 337
18 Jun 2012 16:41 #530124
by bountyhunter
Replied by bountyhunter on topic kz1000-Having trouble removing cylinder head
There are usually a couple of small 10 mm bolts holding it on the get overlooked.
- vintkaw77
18 Jun 2012 20:54 #530200
by vintkaw77
I removed it with unusual but effective technique
thxs
thxs
