Weird cam chain like noise? Need help!
  • AaronOregon
  • Topic Author
  • Live Hard, Ride Free
15 Jun 2012 21:50 - 15 Jun 2012 21:51 #529434 by AaronOregon
Weird cam chain like noise? Need help! was created by AaronOregon
So I went for a 70 mile ride yesterday and when I got back into town I noticed that it was making a really weird noise when I would let off the throttle and there was no load on the engine. I automatically thought cam chain tensioner failure. I tore the tensioner apart today and everything is working good on it. I cleaned it up and lubed it anyhow and when I put it back in the bike I pulled the lock-bolt out and it slammed against the chain guide like it is suppose too. At that point I left the bolt out and rotated the engine a couple revolutions with a ratchet and then inserted the bolt and set the lock nut. Well, I though for sure this would take care of it, but it didn't. It sounds awful when at a light or stop sign now and letting off the engine and taking away the load. Anybody have any ides? The bike runs great when loading the engine or running down the road. Just baffled. It's a constant sound like a chain. Wow, a lot of bugs to work out on an old-school project back from the dead! Thanks!
Aaron
P.S. I checked all my exhaust bolts. It's coming from under the valve cover area.......
1980 KZ750E - Pods - 4 into 1
Last edit: 15 Jun 2012 21:51 by AaronOregon.
  • 4TheKZ1000
  • Visitor
15 Jun 2012 21:56 #529435 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Weird cam chain like noise? Need help!
pull the cover and look around
15 Jun 2012 22:37 #529453 by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Weird cam chain like noise? Need help!
Possible carb synch issue? Does it go away if you raise the idle speed a bit?
Mine rattles and growls when I need a tune up.
Can you post a video on YouTube? This seems to come up occasionally.
Can you describe the ruckus?
  • trianglelaguna
15 Jun 2012 22:42 #529456 by trianglelaguna
Replied by trianglelaguna on topic Weird cam chain like noise? Need help!
the tach drive gear is there too.....my 2 cents
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
15 Jun 2012 22:50 #529457 by 650ed
Replied by 650ed on topic Weird cam chain like noise? Need help!
AaronOregon wrote: So I went for a 70 mile ride yesterday and when I got back into town I noticed that it was making a really weird noise when I would let off the throttle and there was no load on the engine. I automatically thought cam chain tensioner failure. I tore the tensioner apart today and everything is working good on it. I cleaned it up and lubed it anyhow and when I put it back in the bike I pulled the lock-bolt out and it slammed against the chain guide like it is suppose too. At that point I left the bolt out and rotated the engine a couple revolutions with a ratchet and then inserted the bolt and set the lock nut. Well, I though for sure this would take care of it, but it didn't. It sounds awful when at a light or stop sign now and letting off the engine and taking away the load. Anybody have any ides? The bike runs great when loading the engine or running down the road. Just baffled. It's a constant sound like a chain. Wow, a lot of bugs to work out on an old-school project back from the dead! Thanks!
Aaron
I know there are several different types of KZ tensioners, but the way you adjusted yours is WAY different (and not in a good way) than the way my KZ650 is done. Are you positive that the way you adjusted it is how the Kawasaki Service Manual or the Owners Manual describes the process? If not, you should track down and perform the correct procedure before you run and possibly damage the engine. Ed
  • AaronOregon
  • Topic Author
16 Jun 2012 00:09 #529488 by AaronOregon
Replied by AaronOregon on topic Weird cam chain like noise? Need help!
trianglelaguna wrote: the tach drive gear is there too.....my 2 cents
You may be on to something here...........While on the 70 mile ride I noticed my tach started jumping around in the range it was in, where it has not done that in the past. Can I just pull it out and cap it off or what goes wrong with them? Good call!
Aaron
  • wireman
16 Jun 2012 00:13 #529491 by wireman
Replied by wireman on topic Weird cam chain like noise? Need help!
Just unhook the cable from tach drive on head if it has one,no need to cap it off. B)
  • AaronOregon
  • Topic Author
16 Jun 2012 01:43 - 16 Jun 2012 01:44 #529509 by AaronOregon
But I think it is probably the gear, not the cable making the noise. Either it is this or I just need a manual cam chain tensioner.
Last edit: 16 Jun 2012 01:44 by AaronOregon.
  • 4TheKZ1000
  • Visitor
16 Jun 2012 12:40 #529573 by 4TheKZ1000
block the tach hole like this
Attachment bike361.JPG not found
  • AaronOregon
  • Topic Author
16 Jun 2012 13:17 #529582 by AaronOregon
I went ahead and ordered a manual chain adjuster. Between these two things I think it will take care of it hopefully.
Aaron
  • 4TheKZ1000
  • Visitor
16 Jun 2012 13:21 #529583 by 4TheKZ1000
nice bike hope you solve the prob...
16 Jun 2012 20:54 #529693 by tinlizzie37
Replied by tinlizzie37 on topic Weird cam chain like noise? Need help!
Hi Aaron, Make sure you adjust the tensioner according to the factory manual. There is a certain spot where you tighten it against the chain. I put a double wedge type of automatic chain tensioner in my KZ 650 and it's working fine. Maybe you had the junk ball bearing type in your bike. Bob
Bob KZ 650 E1, En 450
