- Thank you received: 299
Adjust valves to middle tolerance allowed?
- wireman
- wireman
faffi wrote:
Sensable people drive volvos,this is a kaw forum we're nuts in general! :woohoo:wireman wrote: Sensible people usually have the best engines
I drive a Volvo :blush:[/quote]
Attachment 1980_volvo_240_glt.jpg not found
now youve gone and marked yourself! :woohoo:
- wireman
- wireman
- 893cv
- Thank you received: 15
How soon from new did that one valve need attention? Every shim and bucket DOHC engine I've serviced has taken a few miles for the valves to settle, then they are good to go for 50-60K. I had a BMW K100 that I did the PDI on that had one intake valve that was always either a little to loose or too tight. It kept that up untill 80,000 miles, then it was fine. Every other K100 & K75 I serviced was good from the mile 1 untill about 80K.
1980 kz1000 LTD
1978 Z1R
- Thank you received: 2829
- faffi
- Thank you received: 36
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
- 893cv
1980 kz1000 LTD
1978 Z1R
- LarryC
893cv wrote: It has been my experience that these motors idle best when the valves are set to the max tolerance, especially the exhaust valves. The carbs are easier to sync. too.
Your answers are the most correct ones.
It's a myth that valves always get tighter. Some do, some don't. See it all the time.
Larry C.
