Boggs down for a few seconds when given throttle
- drakewoodie
1981 KZ550C - Kawasaki 550 LTD
- wireman
- Thank you received: 299
- Thank you received: 2829
- drakewoodie
- Thank you received: 2098
drakewoodie wrote: Well I drained some of the oil out today and took it for a ride no more dripping oil it appears....will put some seafoam in it tomorrow and see what that does
How are you checking the oil level? Are you familiar with the sight glass?
- drakewoodie
I don't believe there is any gas in the crankcase oil. I put some on my finger and didn't smell any gas in it and it still seemed to be the right viscosity.Patton wrote: Would also assure that the crankcase oil isn't contaminated with gasoline.
As far as being familiar with the sight glass I am now. I did some research on proper procedure for filling the oil and now know to put it up on the center stand and then fill till its between the two lines
- drakewoodie
wireman wrote: throw a can of sea foam in the tank to scrub the carbs out
Would you use a whole bottle of seafoam or just the suggested amount.....
- drakewoodie
- Motor Head
- Thank you received: 391
Check the voltage across the battery with the bike running at 4K RPM and lights on. See if it 14v or so, if low start checking the harness. Pull both side covers and open the seat, check the connections and the fuse panel closely. See any sign of heated wiring, it will have resistance causing voltage drop. Use a voltmeter, check the battery voltage, follow along the harness through the connections and see if there is drop.
Hopefully, whatever issue was causing fuel drainage from the overflow circuit has also been resolved.drakewoodie wrote: Update....ran a whole can of seafoam through it engine sounds better but still had issue of it bogging down when the throttle was rolled......was reading the manual and saw steps to try to see if possibly it was running lean or rich.....first was checking to see if it was lean so I tried riding the bike with the choke partially on....this didn't change anything....next step see if its running rich...remove the airfilter and ride the bike.....this resolved the issue....looking at the filter looks lime its coated in oil probably from when I had the oil level too high....so new filter it is....
If not, too high fuel level could still be causing an excessively rich mixture partially masked by running without an air filter which tends toward leaner running.
In other words:
Too high fuel level > too rich.
No air filter > too lean.
The two faulty conditions, working together, tend to cancel each other out.
But it's no way to run a railroad.
- drakewoodie
Patton wrote: Hopefully, whatever issue was causing fuel drainage from the overflow circuit has also been resolved.
In other words:
It wasn't fuel that was over flowing it was oil due to me being new to a bike and overfilling it with oil. I have corrected the issue and it hasn't had anything dripping in quite some time.
