Kick kick kick and it just won't run...
- KZJOE900
- Admin
06 Jun 2012 21:21 #527327
by KZJOE900
+1 on what baldy110 said. If the starter fluid didn't work then its unlikely the carbs. The aerosol atomized starting fluid (fuel) pretty much replaces the function of the carburetors for that brief moment. So it could be your timing, or weak spark or something else.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic Kick kick kick and it just won't run...
baldy110 wrote: If it won't fire on starter fluid then you have an ignition problem.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Hatchet
- It's better in the wind.
- Thank you received: 3
06 Jun 2012 22:11 #527337
by Hatchet
Bikers are a rare breed.
Harley riders are a dime a dozen.
'83 KZ750 LTD K1. "Don't make me get the belt..."
Replied by Hatchet on topic Kick kick kick and it just won't run...
Does the flywheel concept I mentioned last post seem like a feasible explanation?
- Motor Head
- Thank you received: 391
07 Jun 2012 01:31 #527387
by Motor Head
Replied by Motor Head on topic Kick kick kick and it just won't run...
Have you had this bike running before? If so what all have you done, now that it won't start.
- Hatchet
07 Jun 2012 01:45 #527389
by Hatchet
I have not. A long time project.
Motor Head wrote: Have you had this bike running before? If so what all have you done, now that it won't start.
- Motor Head
07 Jun 2012 01:51 #527392
by Motor Head
Ok, so what have you done? motor work? Have the cam chain off? Disassemble any of the engine, or ignition?
- Hatchet
07 Jun 2012 01:59 #527397
by Hatchet
I have not touched any of the internals whatsoever. With the exception of the carburetors, I have not messed with any of the engine parts.
The exception is when I removed the generator cover to remove a broken electric starter chain. When this happened, I carelessly budged the flywheel about a half-turn from where it was.
I am more and more suspecting that this is the problem. Thoughts?
- Motor Head
07 Jun 2012 02:06 #527398
by Motor Head
That would have nothing to do with the engine mechanical timing or effect the ignition timing. Your carbs, you say are getting fuel. You tried starting fluid, but didn't get it to fire. But there was some Kick back, correct? Then checking that the Ignition is firing at the correct time would be a good place to start, but also verifying the engine mechanical timing and compression. Do you have a compression tester?
- Hatchet
07 Jun 2012 02:16 #527399
by Hatchet
Hmm.
Yes, the carbs are getting fuel. And I am experiencing kick back, albeit on a somewhat inconsistent basis (sometimes it kicks all the way through cleanly, other times it kicks me back hard about halfway down).
Nada on the compression tester. I will try to get my hands on one a.s.a.p. in order to check...
Whatever the case, we are narrowing it down.
I appreciate your posts, Motor Head!
- Motor Head
07 Jun 2012 10:11 #527445
by Motor Head
Hopefully you have a service manual for your bike, as that will help you a lot. It will show you how to test the compression, what the spec is, how to check the valve clearances, and check the ignition timing. It will also tell you how to check the mechanical engine timing,thats the relation of the crankshaft to the camshaft. Now on your bike it looks like it should have the Ignition pick-up oont he right side of the cylinder head, under a small cover. It may not be slotted where it bolts down, as they were set up by Kawasaki and not changeable without making slots. You shouldn't need to slot it either if everything is correct. If the cam to crank mechanical timing is off, then of course it will throw off the ignition. Also if the advancer assembly is on incorrectly this can mess up the timing of the ignition. So some simple checks are needed to verify. Rule out the easy stuff first.
