- Thank you received: 3
Kick kick kick and it just won't run...
- Hatchet
- It's better in the wind.
Spark plugs are getting spark.
Carburetors are freshly cleaned and should be adjusted at least to functioning levels...
Fuel lines are good and fuel is flowing.
Oil is fresh, and has been pumped through the bike by the kicker at least 30 times.
Compression on the kicker is good...feels like it should...
Battery is good, all lights are go.
I get the kickstarter all the way down and it sounds like it's about to start ("vwoosh") but comes back up with no result.
The electric starter is non-functioning.
Any general ideas? I'm off to Google to troubleshoot...
Bikers are a rare breed.
Harley riders are a dime a dozen.
'83 KZ750 LTD K1. "Don't make me get the belt..."
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Sorf
- Thank you received: 2098
If carbs have "enrichener circuits" (which add additional fuel mixture) instead of true chokes (restricts air), the enrichener circuit is designed to best function with the throttle slides in their full down position (i.e., throttle completely closed).Hatchet wrote: 1983 KZ750 LTD K1...Spark plugs are getting spark.
Fuel lines are good and fuel is flowing...Compression on the kicker is good...feels like it should...
Battery is good, all lights are go....
If not already doing, try starting the engine without touching the throttle grip.
- Thank you received: 2829
Key on.
Fuel on.
Choke on.
Don't touch throttle.
If bike still won't start check spark plugs. Are they wet or dry? Ed
- Motor Head
- Thank you received: 391
Maybe the Enrichment/ starter jet circuit in your carbs are still dirty/ blocked. How bad were the carbs?
- Hatchet
Fuel is indeed flowing down to the carbs, as the float drain screws are definitely letting out fuel. The carbs themselves were actually not that bad when I cleaned them out - I was expecting much worse than I found. To my knowledge, the starter jets are clear.
The float levels however I am less confident about. I don't think I adjusted those properly, but I was hoping to fine-tune them after getting the bike running...
Although the spark plugs were getting spark, admittedly they did seem a bit weak. They are dry and fairly black.
I am not touching the throttle at all.
I'll try the starter fluid and see if I get any results. I'll also try the idle adjustment screw trick (carefully) and see if that changes anything.
I'm hoping to figure this out without too much difficulty.
- KZJOE900
- Admin
Hatchet wrote: Thank you all for the replies, I appreciate it. Lots of good advice here.
When using starter fluid, try opening the throttle when spraying two or three shots in each bore. Then when trying to kick start it, try to give it about 1/4 to 1/3 throttle as you are kicking. Don't forget to make sure your kill switch is in the run position. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- lemo32
- The Price of Cool aint cheap
1979 kz 1000 06 katana 750
- 4TheKZ1000
- Visitor
- Hatchet
Still haven't tried the idle screws...but I'm done for today (see below).
I went over the bike today and everything still looks good. I am 100% convinced that the spark plugs and fuel lines check out. The rest still looks good but I won't give a gaurantee.
Today however I noticed something. After giving the bike several kicks, a couple of times I noticed a pretty strong "kick back". I stopped messing with it after this, afraid to break anything...
I read online that some Triumph guys experienced no start and a strong kick back because their ignition timing was off.
Does that sound like a possible culprit?
*EDIT* Actually, I just realized a potential screw up. Here's the thing; when I was removing the electric starter chain from the starter clutch, the flywheel may have got moved in the process.
- baldy110
- Thank you received: 512
