- Thank you received: 3
What type of oil
- SeattleKZ
- T_Dub
- Thank you received: 25
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
- Medina
- Thank you received: 8
walmart, cheap, excellent, and very inexpensive and very available.
There is no reason NOT to change that oil once a year or every 1500 miles if you commute it often.
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
- Thank you received: 2829
www.mobiloil.com/USA-English/MotorOil/Oi...acing_4T_10W-40.aspx
- SeattleKZ
T_Dub wrote: Same as it says in your manual. 10W40 motorcycle specific oil.
I've had the bike a month so I don't have the manual.
- SeattleKZ
650ed wrote: You will no doubt get differing opinions, but what ever you decide to use make sure it meets the JASO-MA oil standard. Oils that meet that standard are specifically designed to provide proper lubrication for 4 stroke motorcycle engines with wet clutches - like our KZs have. Regular automotive oils have "friction modifiers" that are not good for wet clutches. Here's what I use:
Thanks for the advice an for being very specific it's really appreciated.
- T_Dub
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- SeattleKZ
T_Dub wrote: I meant owners manual. I guess not all bikes will still have one with it. but it does say on your oil filler cap. At least it does on mine.
I knew you meant owners. It didn't come with one. I guess I should have been more specific. I have the seen the weight is on the oil filler cap. That was manufactured 35 years ago so I was thinking oils have changed so much over that time I better ask. 650ed pointed out some good things I might not have known, I could have used proper weight but bad oil for our wet clutch bikes.
- MFolks
- Thank you received: 540
Engine oil : The commercial grade oils are clearly superior to the mass market oils. For the best protection in your bike or car, use Shell Rotella Synthetic, available at Wal-Mart in blue containers . For the best petroleum oil you can buy, get Shell Rotella T, Mobil Delvac 1300, or Chevron Delo 400, available at any auto parts store. On the back of most oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut.
These oils contain friction modifier additives that could cause clutch slipping over time. The EPA mandated certain gas mileage, so the auto makers turned to the oil manufacturers who came up with friction modifiers of the oil to meet these new standards. All XXw-20 and XXw-30 oils are energy conserving, and should not be used in your motorcycle. Don't buy any oil additives like STP or Slick-50. Here's several listings on all about oil justifying these conclusions.
The Recommended Synthetic Oils :
5w-40 Delvac 1 Synthetic
5w-40 AMSOil AMF Synthetic (pricey, but it’s your money)
10w-40 Golden Spectro Synthetic
10w-50 Motul 5100 Synthetic
10w-40 Mobil-1 Synthetic
15w-50 Mobil-1 MX4T Synthetic
The best synthetics are: (in no particular order)
Shell Rotella-T Synthetic 5w-40 (blue container is synthetic, not white which is dino), gallon at Wal-Mart.
Mobil Delvac-1 5w-40 (grey container is synthetic, not black which is dino), gallon at Petro stations, gallon at Farm and Fleet.
Mobil-1 SUV 5w-40, qt anywhere.
AMSOil AMF 10w-40 synthetic motorcycle oil. (again, pricey)
Golden Spectro Supreme, (no price).
Motul 5100 Ester, (no price).
Mobil-1 automotive oils all contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in some motorcycles. I've only heard of this being a problem in Honda Shadows.
The Recommended Petroleum Oils
Chevron Delo 400 15w-40
Delvac 1300 15w-40
Shell Rotella 15w-40
The best petroleum oils are: (in no particular order)
Chevron Delo 400 15w-40 (blue container) gallon at any auto parts store, gallons at Costco.
Mobil Delvac 1300 15w-40 (black container) gallon at any auto parts store, gallons at Sam's Club.
Shell Rotella-T 15w-40 (white container) gallon at Wal-Mart or any auto parts store, gallons at Sam's Club.
Castrol 15w-40 (Green container) gallon at Wal-Mart or any auto parts store, gallons at Sam’s club.
- bountyhunter
- Thank you received: 337
Rotella is very good and you can get it cheap at walmart in gallon jugs. Castrol GTX is pretty good too.
IMHO, key strategy is to change frequently as MC use beats oil additives up pretty quickly. Changing often (less than 3K miles) also keeps the engine cleaner.
- MFolks
- Thank you received: 2098
Me too. Dino, non-energy conserving, and change oil and filter at 3,000 mi.MFolks wrote: Yep, the engine and transmission will chew up the elements of the oil, as both share the oil supply. I change my bikes oil every 3000 miles.
Perhaps the expensive, synthetic motorcyle-specific oil can go longer between changes.
Haven't tried synthetic motorcycle-specific oil, due to reports that it can sometimes leak past previously oil-tight seals.
Maybe there's no truth in that, but not wanting to risk it.
Meanwhile enjoying clean, dry, well-performing engines.
