J Motor Valve Adjustment Questions?
- KZJOE900
- Admin
06 Jun 2012 03:19 #527189
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic J Motor Valve Adjustment Questions?
Did you turn the cams a couple of revolutions after installing the new shims? This will help seat the new shims down (push out any excess oil) before you take the measurements.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- badrhino
- Thank you received: 6
06 Jun 2012 14:29 #527258
by badrhino
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Replied by badrhino on topic J Motor Valve Adjustment Questions?
Yes sir, like 4-5 times to make sure. Looks like I need to drop another size.
Franken Z!
- badrhino
12 Jun 2012 14:03 #528530
by badrhino
Franken Z!
Well I finally got my valves where I want them. Some on the loose end.
Ex.
1 .14
2 .15
3. .14
4 .10
In.
1. .10
2. .10
3. .10
4. .15
I am thinking some of my shims must have been worn a bit as when I dropped sizes with the new ones I didn't pick up the gains I should have. However I did measure all of the shims with a caliper beforehand. :dry: Oh, well.
Anyhow, next question: Do most of you guys use gasket sealer on the new valve cover gasket?
Ex.
1 .14
2 .15
3. .14
4 .10
In.
1. .10
2. .10
3. .10
4. .15
Franken Z!
- LarryC
12 Jun 2012 17:40 #528565
by LarryC
Larry C.
Replied by LarryC on topic J Motor Valve Adjustment Questions?
Those clearances are fine.
Engine case sealer on the cam end plugs where they slide into the U Groove works best IMO. A dab of high temp RTV on top of those plugs will fill in any minor unevenness.
On J model heads, the valve cover gasket is pretty thin. There's a product from 3Bond called 1215 that works great when a light coating is applied to the valve cover gasket on both sides. It seals but keeps the gasket from baking itself to the aluminum surfaces as well. That can make your next valve adjustment go easier because you don't have to scrape gasket material. In fact, if you're careful removing the cam cover, you may not even rip the gasket.
Larry C.
The following user(s) said Thank You: gravit8
- badrhino
12 Jun 2012 17:47 #528568
by badrhino
Franken Z!
Thanks!
Franken Z!
