- Thank you received: 6
J Motor Valve Adjustment Questions?
- badrhino
They would spin so I think these are good.
Thanks
Ryan
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
- badrhino
Franken Z!
- badrhino
Franken Z!
- wireman
- Thank you received: 299
- badrhino
Franken Z!
- wireman
the cam lobe will catch on the inside ridge of the bucket without a shim in there and do bad things to that nice shiny cam lobe. :sick: :blink: :pinch: :S :blush:
Thats why I keep extra shims laying around for doing them.
- badrhino
Franken Z!
- wireman
I use the cam to push down the bucket and shim then I have a little wedge I put between the edge of bucket and the cam(not the journal)to hold it down while I back the the cam up then I swap the shims and reverse process to remove the wedge.badrhino wrote: How are you supposed to swap shims from on cylinder to another if need be without doing so. Do you have to take the cams out. If that's the case why did I waste money on the Motion Pro tool?
- wireman
- LarryC
Larry C.
- wireman
- badrhino
Franken Z!
