Help! Valve Adjustment
23 May 2012 23:35 - 23 May 2012 23:39 #524393 by adr3naline
Help! Valve Adjustment was created by adr3naline
Today I tested the compression on my 1979 KZ650. Cold and kickstarted, I had 75, 65, 80, and 75.
So, I decided to check the valve clearances to see if I could improve the compression. The clearances I got were (based on feeler gauge sizes): Exhaust - .178, .152, .152, .203, Intake - .102, .063, .076, .102.
Then I checked the shim sizes, based on the numbers written on the shims: Exhaust - 2.60, 2.50, 2.55, 2.50, Intake - 2.55, 2.65, 2.65, 2.50.
I decided to swap shims around so that my clearances were closer to .10 to .15, and I swapped them to this: Exhaust - 2.65, 2.50, 2.55, 2.55, and Intake - 2.50, 2.60, 2.65, 2.50. Based on these changes, I should have the following new clearances: Exhaust - .128, .152, .152, .153, and Intake - .152, .113, .076, and .102.
I made sure to keep the chain tight while pulling buckets to check/replace shims.
When I got it all bolted back up, I rotated the engine a few times to make sure everything was seated. I checked the clearances again... and I couldn't even get my smallest shim between some of these buckets, but the best was .102! I must have done something wrong. My timing chain, before I took off the idler, had some slack in it. Now, it's super tight.
I think that's everything I can remember doing... can you help me? What did I do wrong?
Thank you!
adr3naline
1979 KZ650sr
1979 CB650
Last edit: 23 May 2012 23:39 by adr3naline. Reason: forgot one part
  • munkybrain2010
  • Clueless..
24 May 2012 02:04 #524432 by munkybrain2010
Replied by munkybrain2010 on topic Help! Valve Adjustment
Are the buckets in their original valve? I dont know if they would change that much even with the same shims left in if you had switched the buckets. Apparently it makes adjusting after that more difficult.
did you tighten you cam chain tensioner with a longer bolt if its the auto like my 79 before you took off the idler?
Keep it together man!
79 KZ650 "Geto Cycle"
24 May 2012 10:26 #524495 by adr3naline
Replied by adr3naline on topic Help! Valve Adjustment
Thanks for getting back with me.
No, the buckets are the exact same at each valve. And I didnt make any adjustments to my chain tensioner.
adr3naline
1979 KZ650sr
1979 CB650
  • Motor Head
24 May 2012 10:34 #524501 by Motor Head
Replied by Motor Head on topic Help! Valve Adjustment
If the chain is "Super Tight" it is most likely not on the crankshaft sprocket correctly.
24 May 2012 11:15 #524513 by adr3naline
Motor Head wrote: If the chain is "Super Tight" it is most likely not on the crankshaft sprocket correctly.
So, I can rotate the engine fine though... Is there a way to verify that's it's not on the crank sprocket correctly?
adr3naline
1979 KZ650sr
1979 CB650
24 May 2012 11:42 #524519 by Patton
Replied by Patton on topic Help! Valve Adjustment
May locate some info through one of these links about re-setting the tensioner.
www.kz650.info/
jarlef.no/Kawasaki/Series/Z/650/z650files.htm
Good Fortune! :)
  • munkybrain2010
  • Clueless..
24 May 2012 16:52 #524555 by munkybrain2010
The manual says to stop the tensioner with a longer bolt before removal of the cam shafts. if you took slack off the chain the tensioner may have pushed out too far. You should make sure the chain is on tight (no slack between sprocket and crank)on the exhaust side and then timed right with the intake. if the chain is still too tight you may have to tighten the tensioner down with a longer bolt and take it off to see if that is the problem.
Im also curious about the differences in spec too though. I did the same exact thing, rearranging shims and buying two new ones to put it in theoretical spec, but upon inspection only one was at .152! it runs like a rocket though and the spark plugs look MUCH better still.
